[QGIS-Developer] QgsPythonRunner in standalone app
VOLPES-EXT, Jacky Jacky.VOLPES-EXT at canal-de-provence.com
Wed Oct 16 06:03:26 PDT 2019
Hi (again) !
I figured out (after 2 days of research !) that in a standalone app, to be able to open a custom layer form when identifying a feature, I have to implement a specific QgsPythonRunner child class (code below).
And then I have to set the QgsPythonRunner.
The problem is that I can't get evalCommand() to work because the variable result is a C++ reference, and python can't deal with it, can it ?
Maybe there is a workaround I didn't think through, or there is a need to pass result as a return value ?
Thanks !
BR
class PythonRunnerStandalone(QgsPythonRunner):
    def __init__(self):
        super().__init__()
    def runCommand(self, command, messageOnError):
        try:
            exec(command, globals())
            return True
        except Exception as e:
            if messageOnError == "":
                print("Error with command:\n")
            else:
                print(messageOnError + "\n")
            print(command)
            print("Catched exception:\n", e)
            return False
    def evalCommand(self, command, result):
        try:
            result = eval(command)  # problem here
            return True
            print(command)
            return False
qgis.core.QgsPythonRunner.setInstance(PythonRunnerStandalone())
In QGIS source code qgis-latest/qgis-3.8.2/src/gui/qgsattributeform.cpp lines 1610-1625:
    QString numArgs;
    // Check for eval result
    if ( QgsPythonRunner::eval( QStringLiteral( "len(inspect.getargspec(%1)[0])" ).arg( initFunction ), numArgs ) )  // Here numArgs is passed as reference to my python implementation
      if ( numArgs == QLatin1String( "3" ) )   // always fails here
Jacky Volpes
HR Team pour la Société du Canal de Provence | 2SI - QGIS
Le Tholonet, CS70064
jacky.volpes-ext at canal-de-provence.com<mailto:jacky.volpes-ext at canal-de-provence.com>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191016/0cff2a4d/attachment.html>
More information about the QGIS-Developer mailing list
