[QGIS-Developer] v.net.centrality: Sorry, <points> is not a valid parameter
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Thu Oct 31 01:25:02 PDT 2019
I have no idea what this function does, but when trying with your data
on 3.10 on Linux without any default parameter changes, it first
complains about a wrong output type, because in the advanced parameters,
there is no output type selected by default. Switching this to auto
gives a resulting point layer.
Cheers,
Bernd
Am 31.10.19 um 09:13 schrieb magerlin:
> In trying to use v.net.centrality I get the error "Sorry, <points> is not a
> valid parameter"
> I have tried several settings when running but keep on getting this error -
> cannot figure out from where the word <points> origins - it must be
> something internal in the script as I am not using this word.
> Data sample is here: Poi.zip
> <http://osgeo-org.1560.x6.nabble.com/file/t202356/Poi.zip>
> Regards Morten
> Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.10.0 in parallel
> Windows 7, 64bit
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
