[QGIS-Developer] v.net.centrality: Sorry, <points> is not a valid parameter
magerlin MAP at ramboll.dk
Thu Oct 31 07:35:07 PDT 2019
Thanks for clearing that up....
I have made v.net.centrality run in QGIS 2.18 without any problems - even
though the setup is a little different in 2.18 as you do not need to provide
a point layer and you unfortunately cannot add costs on the network.
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.10.0 in parallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
