[QGIS-Developer] Raster calculator problems
kozskan at seznam.cz
Wed Sep 4 02:37:36 PDT 2019
Dear All,
I am dealing with raster calculator issue and I am not quite sure about the
algorithm of this tool, it seems that it somehow does not work in way I
would liked to. I discussed this issue on GIS stackexchange and people
assumed that the sytax is correct. The version of QGIS I am using is 3.8.0.,
also I've tried to use previous releases but none worked.
The thing is that I have a 1-band geotif raster and I use following syntax
in order to create output raster where values from the 1-band raster
represents following table. In other words, I have a raster layer with
values ranging from 0.00597303 to 0.102894 and I want to assign specific
number representing a group to specific range of values:
Group 4: x >= 0.1
Group 3: 0.01 <= x < 0.1
Group 2: x < 0.01
I am using the following syntax:
("Ri_Q50 at 1" >= 0.1) * 4 + (("Ri_Q50 at 1" >= 0.01) AND ("Ri_Q50 at 1" < 0.1)) * 3
+ ("Ri_Q50 at 1" < 0.01) * 2
But the output is not quite what I am looking for - I think that raster
calculator should be suitable to do this job.
I don't know what else could be the problem then my unsufficient knowladge
of the algorithm of raster calculator.
I would be very greatful for any kind of advice.
Thank you very much for help, I appreciate that.
Kind regards
Václav
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190904/6b9f2a1c/attachment.html>
