[QGIS-Developer] How do I define a marker offset with an expression.
Chris Crook ccrook at linz.govt.nz
Thu Sep 5 19:16:48 PDT 2019
Hi All
I am trying to offset a marker (ellipse or simple marker).  I can easily do this by entering values into the Offset x and y fields (eg 20.0, 30.0 mm).
However I haven't figured out how to enter this as an expression.  I have entered an expression as "array(20.0,30.0)" but the symbol remains at its unadjusted offset.
Have I got the expression syntax entered incorrectly?
Thanks
Chris
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
More information about the QGIS-Developer mailing list
