[QGIS-Developer] UI ideas to fix opening of certain OSM files
Stephen Knox
stephenknox73 at gmail.com
Tue Sep 10 17:02:23 PDT 2019
I've started work on creating a PR for htis, but I am a bit confused by the
number of potential classes I could use and tying the calls together. It
seems like I could use one (or all of) QgsDataProvider::ProviderOptions,
QgsVectorLayer::LayerOptions or QgsDataProvider::ProviderProperty
(with QgsDataProvider::providerProperty
and QgsDataProvider::setProviderProperty. Have they all been added at
different times, or are they meant for different use cases? There doesn't
seem to be a path from the UI all the way through to the GDAL calls so I
presume that no one has done this before? It seems like something that
should be available as an option.
Thanks in advance
Stephen
On Tue, Aug 6, 2019 at 10:32 PM Stephen Knox <stephenknox73 at gmail.com>
wrote:
> I would just like to draw your attention to issue 30162
> https://github.com/qgis/QGIS/issues/31062.
> I would appreciate any comments on what people with more experience than I
> do think about my two different ideas to fix this bug. It has clearly been
> an issue in the past as there are issues referencing the same error message
> which were closed through being stale rather than a commit to fix.
> Another option is to make people set an environment variable to load the
> files properly, but this seems a very sub-optimal solution.
> Let me know if anything is unclear.
> Thanks
> Stephen
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190911/7d3a03d3/attachment-0001.html>
