[QGIS-Developer] Build error: qgsspatialiteprovider.cpp undefined reference to `sqlite3_column_table_name'
Matthias Kuhn matthias at opengis.ch
Wed Sep 11 23:12:41 PDT 2019
Hi Sinan,
Glad you solved the problem.
As it sounds, it's likely that on your system the build process picked
up different header files than library files (e.g. system installation
vs. custom build of sqlite).
Best regards
Matthias
On 9/12/19 4:56 AM, Sinan Bulut wrote:
> After some googling, it turned out that sqlite should be compiled with
> SQLITE_ENABLE_COLUMN_METADATA preprocessor flag as mentioned in
> https://sqlite.org/compile.html. It would be very useful if this
> detail is added to the installation instructions. After this fix,
> QGIS build successfully completed.
> On Wed, Sep 11, 2019 at 1:28 PM Sinan Bulut <sbulut at 3vgeomatics.com
> <mailto:sbulut at 3vgeomatics.com>> wrote:
>     It seems the formatting of my previous email was modified during
>     transmission. So, below I am attaching the cmake configuration
>     summary. Also attached is the build log. Note in these files I
>     simplified the long software installation prefix from "/disk/..."
>     to simply '/disk'
>     Thank you in advance for you help!
>     On Tue, Sep 10, 2019 at 11:11 AM Sinan Bulut
>     <sbulut at 3vgeomatics.com <mailto:sbulut at 3vgeomatics.com>> wrote:
>         Hi all,
>         I am trying to build QGIS  from source in Linux. In the
>         process I am getting the following error:
>         /  11979
>          CMakeFiles/spatialiteprovider.dir/qgsspatialiteprovider.cpp.o: In
>                        function `QgsSpatiaLiteProvider::checkLayerType()':
>           >> 11980
>          /cache/sbulut/spack-stage/qgis-3.8.1-d3sanusy3l7fa7br72lkqgfzaeqc
>         gvjj/spack-src/src/providers/spatialite/qgsspatialiteprovider.cpp
>                       :4691: undefined reference to
>           >> 11981    collect2: error: ld returned 1 exit status
>           >> 11982    make[2]: ***
>         [output/lib/qgis/plugins/libspatialiteprovider.so] E
>                       rror 1
>         I would really appreciate some help.
>         Cmake configuration output is:
>         /-- Cache values
>         BINDINGS_GLOBAL_INSTALL:BOOL=FALSE
>         BISON_EXECUTABLE:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/bison-3.0.5-pphkqxfee3diphblp3cowglecwh4czdp/bin/bison
>         BUILD_TESTING:BOOL=ON
>         CCACHE_FOUND:FILEPATH=CCACHE_FOUND-NOTFOUND
>         CMAKE_BUILD_TYPE:STRING=RelWithDebInfo
>         CMAKE_ENABLE:BOOL=ON
>         CMAKE_INSTALL_PREFIX:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm
>         CMAKE_INSTALL_RPATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libbsd-0.9.1-dyl2vvvtdc5kh3m54fn4qoeygl57jkve/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/json-c-0.13.1-rw2ccihpjzuwpliphgzzm5fdcdl3pvcl/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libgeotiff-1.4.3-irbocdu7a46pra2w5pry6kidhu2jodl4/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libtiff-4.0.10-3yg5asc6gbydkygungpzrngjeazarfs2/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xz-5.2.4-vewnijktsjco3mbf2ycv6irlvlur46uq/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/zlib-1.2.11-25pskdmfdd52x3ewomarucg3eu6mswte/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/readline-7.0-i7lun5u3bo6g2lzux5u4acj44git37a4/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/ncurses-6.1-svwt4yh6tdtt7qtfuefht5d2bpll3f2p/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/freexl-1.0.5-lhvygj44p4qf2dwn2vyk43vgczjnwsj5/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/openssl-1.1.1b-yve6linxesmf5ynifakldny7lvl7fqrb/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/bzip2-1.0.8-mhidm2g4rrgf4f5gwpfcr5ginof26cfb/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdbm-1.18.1-uuaf3p4z4exk2ihi2wz54cugd34zhnmc/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gettext-0.19.8.1-5semcqgu6zyde443l7krttz3hjcdcwyv/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxml2-2.9.9-eivopfmxityds3u5eiy5oaldlxj3qzk3/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libiconv-1.15-zcopnqqheh3vbmlybsrltd4wj246vt64/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libffi-3.2.1-imfzbzcglr6k4rst2l7zk55ozwumehmd/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/dbus-1.12.8-ncx6bvfomsvswh72pya2jkvy5xjeeq3r/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/glib-2.56.3-gbmrmjjl5bi4dj32anhlvmxilmbhfprb/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pcre-8.42-3utfouiv6d3lfevuyujknnesugyyqqnk/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/double-conversion-2.0.1-7ycc2v3ldaynxsv6sacztkshhprsahoz/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/fontconfig-2.12.3-f6wln5spslatlsdkqhcvf7lnihdr2axk/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/font-util-1.3.2-q53vtsbmlomlkzivvb23ygmz4ibwicds/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/freetype-2.9.1-ozdurnycg4s2fhabxutfi7eoetrlyzxn/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libpng-1.6.34-milcr4breerhkz5bo3iskwxb2xank4sz/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/harfbuzz-2.3.1-v5gzjngzd2pvc7tg3eohmovo445qndir/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/cairo-1.16.0-uyv25dnwjeb5f5jpjn4qxuoqs53kgpob/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pixman-0.38.0-tz2pwy5opv67qnmrcb2cfodm36mk5qbz/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/icu4c-64.1-yfpzkt6lphbpbbibq3usei5fwjwrrfrp/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libmng-2.0.3-mnfjnd6ekvqhjleankz4hlytfv2d4z4d/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/lcms-2.9-kz4jvl36axs6o4jam73u2zabm6fnlzpu/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libx11-1.6.7-x2yopo37atbfrhwkxukar3ep3yrxiqlp/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/kbproto-1.0.7-ahe42hqnlpckswujtljjx2gpz22qk6vn/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxcb-1.13-3lnuly4szk67d7rxi67omzrvcffnrjsv/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libpthread-stubs-0.4-5hapw23celfhds7vgodxus5kag3bkct6/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxau-1.0.8-vfq3u2pzceaerfzyc2qc427nwogquepe/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xproto-7.0.31-6hdy5fp7v5cm2locbre5nqykczwgzltc/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxdmcp-1.1.2-dhfogcdfrrxe663btar3quv4q4xbpd4n/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xextproto-7.3.0-5b47ttepewybjbsojrc2zcfuztgkv5dh/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxkbcommon-0.8.2-rpc25scjaafjg6g6qzbk5nrcblrnaxwq/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/mesa-18.3.6-vdrrpxyvhxzykhknyn5y2wx2yuylz2xa/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxext-1.3.3-b5wyw67ycgbb3hvkqs775jlrejgmgtbh/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/llvm-8.0.0-4ehepghgagyptkkbdpbwhbavr3blvary/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/binutils-2.32-uenxjpsx2w3hw2qkgdhcm2vlbmtmvjwj/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libedit-3.1-20170329-6qtkllhibhos2ggkj75mqje26nw4oftx/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pcre2-10.31-7sf7mbvnkn5numykdri6lyousgso5yfi/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-image-0.4.0-v3u4zpinbj3d6etu7mkog6zy7yxadftp/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-0.4.0-uooyrh4wijr6zz6bclbkhfx67fcdo33b/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-keysyms-0.4.0-idejxzhv5eo5m6neaerx232mitecstip/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-renderutil-0.3.9-evxsjsdov2ejpey6fey4iz3tmbwdssgh/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-wm-0.4.1-hjzc5mctna3lnacbirdjcvvpxy7jdud3/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qjson-0.9.0-sjy3h7monuilnmdk2xy56qrqnnjcarcg/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libsecret-0.18.8-4wtijixagq33esbwskhotmromadblpjg/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gobject-introspection-1.56.1-o64zy43idux7mllglqyfw4tqv2x7earr/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libgcrypt-1.8.4-o4ax3k3xkn7qcwsyahsz6tu6hnj4zlrn/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libgpg-error-1.36-bggto6d7niqmtfac5r5nvdoaaux24ztt/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwtpolar-1.1.1-vcw6fxzh42vdmrj3f74z36f2omvn66gi/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libjpeg-turbo-2.0.2-ku6fmszupmoh7kf2ele4hhuvlvwsh5nw/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libffi-3.2.1-imfzbzcglr6k4rst2l7zk55ozwumehmd/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco/lib64
>         CMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=FALSE
>         CMAKE_PREFIX_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qjson-0.9.0-sjy3h7monuilnmdk2xy56qrqnnjcarcg;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/cmake-3.15.1-gxyqb6bcuppyki7tajwhbfchkwarurjf;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-requests-2.21.0-4sanp2fu6cwhjagq36pmjlrcwuz2blnm;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/flex-2.6.4-4i5jekvrmxofj2xuqwmfie5l6zfdvxjc;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwtpolar-1.1.1-vcw6fxzh42vdmrj3f74z36f2omvn66gi;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-psycopg2-2.7.5-ei5cxbwiunktqqooofxe65ylwnsaovhv;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/bison-3.0.5-pphkqxfee3diphblp3cowglecwh4czdp;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pkg-config-0.29.2-ve3sm4pl352lbca2f563zyjpc6eq4hvi
>         CXX_EXTRA_FLAGS:STRING=
>         DISABLE_DEPRECATED:BOOL=FALSE
>         ENABLE_COVERAGE:BOOL=FALSE
>         ENABLE_MODELTEST:BOOL=FALSE
>         ENABLE_MSSQLTEST:BOOL=FALSE
>         ENABLE_ORACLETEST:BOOL=FALSE
>         ENABLE_PGTEST:BOOL=FALSE
>         ENABLE_TESTS:BOOL=TRUE
>         EXIV2_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney/include
>         EXIV2_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney/lib64/libexiv2.so
>         EXPAT_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i/include
>         EXPAT_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i/lib/libexpat.so
>         FLEX_EXECUTABLE:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/flex-2.6.4-4i5jekvrmxofj2xuqwmfie5l6zfdvxjc/bin/flex
>         GDAL_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/bin/gdal-config
>         GDAL_CONFIG_PREFER_FWTOOLS_PATH:STRING=/bin_safe
>         GDAL_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/bin
>         GDAL_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/include
>         GDAL_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/lib/libgdal.so
>         GENERATE_COVERAGE_DOCS:BOOL=FALSE
>         GEOS_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/bin/geos-config
>         GEOS_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/bin
>         GEOS_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/include
>         GEOS_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/lib/libgeos_c.so
>         GEOS_LIB_NAME_WITH_PREFIX:STRING=-lgeos_c
>         GSL_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow/bin/gsl-config
>         GSL_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow/bin
>         GSL_EXE_LINKER_FLAGS:STRING=-Wl,-rpath,
>         HDF5_C_LIBRARY_dl:FILEPATH=/usr/lib64/libdl.so
>         HDF5_C_LIBRARY_hdf5:FILEPATH=/usr/lib64/libhdf5.so
>         HDF5_C_LIBRARY_m:FILEPATH=/usr/lib64/libm.so
>         HDF5_C_LIBRARY_sz:FILEPATH=/usr/lib64/libsz.so
>         HDF5_C_LIBRARY_z:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/zlib-1.2.11-25pskdmfdd52x3ewomarucg3eu6mswte/lib/libz.so
>         LIBZIP_CONF_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/lib/pkgconfig
>         LIBZIP_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/include
>         LIBZIP_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/lib/libzip.so
>         NETCDF_INCLUDE_DIR:PATH=NETCDF_INCLUDE_DIR-NOTFOUND
>         NETCDF_LIBRARY:FILEPATH=NETCDF_LIBRARY-NOTFOUND
>         PEDANTIC:BOOL=TRUE
>         POSTGRESQL_PREFIX:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs
>         POSTGRES_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/bin/pg_config
>         POSTGRES_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/bin
>         POSTGRES_INCLUDE_DIR:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/include
>         POSTGRES_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/lib/libpq.so
>         PROJ_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3/include
>         PROJ_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3/lib/libproj.so
>         PYRCC_PROGRAM:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/bin/pyrcc5
>         PYTHON_INCLUDE_PATH:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6/include/python3.7m
>         PYTHON_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6/lib/libpython3.7m.so
>         <http://libpython3.7m.so>
>         PYTHON_TEST_WRAPPER:STRING=
>         PYUIC_PROGRAM:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/bin/pyuic5
>         QCA_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j/include/Qca-qt5/QtCrypto
>         QCA_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j/lib/libqca-qt5.so
>         QGIS_QML_SUBDIR:STRING=qml
>         QGIS_SERVER_MODULE_SUBDIR:STRING=lib/qgis/server
>         QML_IMPORT_PATH:PATH=
>         QSCINTILLA_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv/include
>         QSCINTILLA_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv/lib/libqscintilla2_qt5.so
>         QSCI_SIP_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/share/sip/PyQt5
>         QTKEYCHAIN_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco/include/qt5keychain
>         QTKEYCHAIN_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco/lib64/libqt5keychain.so
>         QT_DOC_URL:STRING=http://doc.qt.io/qt-5/
>         QT_LRELEASE_EXECUTABLE:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/bin/lrelease
>         QWT_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx/include
>         QWT_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx/lib/libqwt.so
>         Qt5Concurrent_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Concurrent
>         Qt5Core_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Core
>         Qt5DBus_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5DBus
>         Qt5Gui_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Gui
>         Qt5Network_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Network
>         Qt5Positioning_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Positioning
>         Qt5PrintSupport_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5PrintSupport
>         Qt5Qml_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Qml
>         Qt5QuickWidgets_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5QuickWidgets
>         Qt5Quick_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Quick
>         Qt5SerialPort_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5SerialPort
>         Qt5Sql_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Sql
>         Qt5Svg_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Svg
>         Qt5Test_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Test
>         Qt5UiTools_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5UiTools
>         Qt5Widgets_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Widgets
>         Qt5Xml_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5Xml
>         SPATIALINDEX_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom/include
>         SPATIALINDEX_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom/lib/libspatialindex.so
>         SPATIALITE_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut/include
>         SPATIALITE_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut/lib/libspatialite.so
>         SQLITE3_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a/include
>         SQLITE3_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a/lib/libsqlite3.so
>         TXT2TAGS_EXECUTABLE:FILEPATH=TXT2TAGS_EXECUTABLE-NOTFOUND
>         USE_CCACHE:BOOL=ON
>         USE_OPENCL:BOOL=OFF
>         WERROR:BOOL=FALSE
>         WITH_3D:BOOL=FALSE
>         WITH_ANALYSIS:BOOL=TRUE
>         WITH_APIDOC:BOOL=FALSE
>         WITH_ASTYLE:BOOL=FALSE
>         WITH_BINDINGS:BOOL=TRUE
>         WITH_CUSTOM_WIDGETS:BOOL=FALSE
>         WITH_DESKTOP:BOOL=TRUE
>         WITH_GEOREFERENCER:BOOL=TRUE
>         WITH_GLOBE:BOOL=FALSE
>         WITH_GRASS7:BOOL=OFF
>         WITH_GUI:BOOL=TRUE
>         WITH_INTERNAL_MDAL:BOOL=TRUE
>         WITH_INTERNAL_O2:BOOL=ON
>         WITH_OAUTH2_PLUGIN:BOOL=TRUE
>         WITH_ORACLE:BOOL=FALSE
>         WITH_POSTGRESQL:BOOL=TRUE
>         WITH_PY_COMPILE:BOOL=FALSE
>         WITH_QSPATIALITE:BOOL=OFF
>         WITH_QT5SERIALPORT:BOOL=TRUE
>         WITH_QTMOBILITY:BOOL=FALSE
>         WITH_QTWEBKIT:BOOL=OFF
>         WITH_QUICK:BOOL=FALSE
>         WITH_QWTPOLAR:BOOL=FALSE
>         WITH_SERVER:BOOL=FALSE
>         WITH_STAGED_PLUGINS:BOOL=TRUE
>         WITH_TXT2TAGS_PDF:BOOL=FALSE
>         _find_lib_python_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindLibPython.py
>         _find_pyqt5_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindPyQt5.py
>         _find_qsci_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindQsci.py
>         _find_sip_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindSIP.py/
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190912/123508e9/attachment-0001.html>
More information about the QGIS-Developer mailing list
