[QGIS-Developer] QGIS FCGI Server 3.9.0 - JPEG renders but PNG empty
Tom Vanzieleghem
tom.vanzieleghem at gmail.com
Fri Sep 27 02:27:38 PDT 2019
Dear all,
I've compiled QGis 3.9.0-Master from source on CentOS Linux release 7.7,
mainly to deploy the QGis Mapserver.
At first sight the mapserver works but only renders jpeg format WMS
requests, png format request are empty. No errors in the qgisserver or
apache log.
Probably due to a mismatch in compiled libraries I guess. I've compiled
PROJ, GEOS, GDAL, LibSpatialite, exiv2 before hand.
PROJ 6.2.0
GEOS 3.7.2
GDAL 3.0.1
LibSpatialite 4.3
exiv2 0.27.2
Others are installed from packages.
As there are no error logs I've no idea which library could cause the
issue?
I would appreciate any suggestions which could point me in the right
direction?
My httpd configuration is as follows
FcgidInitialEnv LC_ALL "en_US.UTF-8"
FcgidInitialEnv PYTHONIOENCODING UTF-8
FcgidInitialEnv LANG "en_US.UTF-8"
# QGIS SERVER log (different from apache logs)
FcgidInitialEnv QGIS_SERVER_LOG_FILE /data/qgis/server/log/serverlog.log
FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
FcgidInitialEnv QGIS_DEBUG 1
FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/data/qgis/server/db"
FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE
"/data/qgis/server/db/qgis-auth.db"
SetEnv PGSERVICEFILE /data/qgis/server/pg_service.conf
FcgidInitialEnv PGPASSFILE "/data/qgis/server/.pgpass"
ScriptAlias /cgi-bin/ /opt/qgis/bin/
<Directory "/opt/qgis/bin">
AllowOverride None
Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
Require all granted
</Directory>
<IfModule mod_fcgid.c>
FcgidMaxRequestLen 26214400
FcgidConnectTimeout 60
</IfModule>
best regards,
Tom Vanzieleghem
RAAP BV
Netherlands
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190927/acd2543d/attachment.html>
