[QGIS-Developer] Build fails on Ubuntu 18.04
Clemens Raffler
clemens.raffler at gmail.com
Fri Apr 3 01:26:17 PDT 2020
Hi Werner,
thanks for the hint (also @Martin Dobias) - it solved the build problem.
I was missing the protobuf-compiler package.
Best regards,
Clemens
On 03.04.20 10:15, Werner Macho wrote:
> Hi Clemens,
> I had the same problem.
> Installing the libprotobuf-dev and protobuf-compiler package helped.
> (Thanks to Martin Dobias for the hint)
> regards
> Werner
> On Fri, 2020-04-03 at 10:07 +0200, Clemens Raffler wrote:
>> Dear Devs,
>> I am currently working on some processing algorithms and wanted to
>> rebase my branch on master. But since yesterdays pull of the latest
>> commits (some also concerning a fix of the windows build), cmake
>> complains that 'Protobuf library's 'protoc' tool was not found!'.
>> Does
>> anyone know the cause for this problem or how to fix it? I am working
>> on
>> Ubuntu 18.04.4.
>> Thanks!
>> Best regards,
>> Clemens
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
