[QGIS-Developer] QGIS unstable on debian testing
Sebastiaan Couwenberg
sebastic at xs4all.nl
Fri Apr 10 21:37:47 PDT 2020
On 4/11/20 1:02 AM, uclaros wrote:
> I was hoping to avoid building everything from source, but if I am to build
> an older proj version, what other packages should I look into rebuilding?
Everything that depends on libproj19, you can find those with:
apt-cache rdepends libproj19
But that lacks the order in which they need to be rebuilt, for the qgis
dependency chain it's:
* proj
* libgeotiff
* python-pyproj
* spatialite
* gdal
* pdal
* saga
* grass
* qgis
Or consult the transition tracker:
https://linuxminded.nl/debian/gis-transitions/html/proj.html
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
