[QGIS-Developer] Travis tests failing with bad argument to internal function
Jorge Gustavo Rocha jgr at di.uminho.pt
Mon Apr 13 08:37:16 PDT 2020
Travis tests are failing. It already happened in my PR, but I've checked
other PR and the error is the same.
There is no problem running the same tests locally.
The failure is like this:
ERROR: testValidateNative (__main__.TestQgsLayerMetadata)
SystemError: ../Objects/dictobject.c:1561: bad argument to internal function
The above exception was the direct cause of the following exception:
  File "/root/QGIS/tests/src/python/test_qgslayermetadata.py", line 417,
in testValidateNative
    self.assertEqual(list[0].identifier, 0)
  File "/usr/lib/python3.6/unittest/case.py", line 828, in assertEqual
    assertion_func = self._getAssertEqualityFunc(first, second)
  File "/usr/lib/python3.6/unittest/case.py", line 808, in
    if type(first) is type(second):
SystemError: <class 'type'> returned a result with an error set
Does anybody know why this is happening?
Regards from #home
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
More information about the QGIS-Developer mailing list
