[QGIS-Developer] QGIS unstable on debian testing
Richard Duivenvoorde
rdmailings at duif.net
Tue Apr 14 07:12:37 PDT 2020
On 4/14/20 1:04 PM, uclaros wrote:
> QgsGeometry.fromWkt('Polygon ((0 0, 1 1, 1 0, 0
> 0))').intersection(QgsGeometry.fromWkt('Point (42 0)'))
Ok, THIS is a good test!!
I can confirm/crash with this one :-(
BUT on 3.10, 3.12 AND current master!!
I also tested on current Windows nightly, there QGIS does not crash but
shows me:
QgsGeometry: PointZ (0 0 nan)
which also is a little strange...?
should this be valid anyway?
I also ran this on Debian in gdb:
(Note that I recompiled all yesterday because bullseye had now python 3.8)
If I run QGIS in gdb (it stops in a thread, but 'continue'-ing for a
couple of times QGIS just starts.
Then copying your python script above in the python console, QGIS
crashes. 'bt' in gdb then shows:
Thread 1 "qgis" received signal SIGABRT, Aborted.
__GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
50 ../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) bt
#0 __GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#1 0x00007ffff2e5355b in __GI_abort () at abort.c:79
#2 0x0000555555564305 in qgisCrash(int) (signal=11) at
../src/app/main.cpp:360
#3 0x00007ffff2e697e0 in <signal handler called> () at
/lib/x86_64-linux-gnu/libc.so.6
#4 0x00007fffed8ebcbd in GEOSCoordSeq_getXYZ_r () at
/usr/lib/x86_64-linux-gnu/libgeos_c.so.1
#5 0x00007ffff5553241 in QgsGeos::coordSeqPoint(GEOSCoordSeq_t const*,
int, bool, bool) (cs=0x7fffe8b51200, i=0, hasZ=true, hasM=false) at
../src/core/geometry/qgsgeos.cpp:1276
#6 0x00007ffff5552366 in QgsGeos::fromGeos(GEOSGeom_t const*)
(geos=0x7fffc800e710) at ../src/core/geometry/qgsgeos.cpp:1098
#7 0x00007ffff5553980 in QgsGeos::overlay(QgsAbstractGeometry const*,
QgsGeos::Overlay, QString*) const (this=0x7fffffffa070,
geom=0x55555ec6fdf0, op=QgsGeos::OverlayIntersection,
errorMsg=0x55555ec6f370) at ../src/core/geometry/qgsgeos.cpp:1434
#8 0x00007ffff554e3cb in QgsGeos::intersection(QgsAbstractGeometry
const*, QString*) const (this=0x7fffffffa070, geom=0x55555ec6fdf0,
errorMsg=0x55555ec6f370) at ../src/core/geometry/qgsgeos.cpp:219
#9 0x00007ffff552717c in QgsGeometry::intersection(QgsGeometry const&)
const (this=0x55555ec6f360, geometry=...) at
../src/core/geometry/qgsgeometry.cpp:2384
#10 0x00007fff493ed43d in meth_QgsGeometry_intersection(PyObject*,
PyObject*, PyObject*) (sipSelf=0x7fffd94d28b0, sipArgs=0x7fffd97bf1c0,
sipKwds=0x0) at python/core/sip_corepart2.cpp:94879
#11 0x00007fffa9d531b8 in () at
/usr/lib/x86_64-linux-gnu/libpython3.8.so.1.0
#12 0x00007fffa9d53577 in _PyObject_MakeTpCall () at
#13 0x00007fffa9b25083 in () at
#14 0x00007fffa9b2d467 in _PyEval_EvalFrameDefault () at
#15 0x00007fffa9c7779b in _PyEval_EvalCodeWithName () at
#16 0x00007fffa9c77b1e in PyEval_EvalCodeEx () at
#17 0x00007fffa9c77ecb in PyEval_EvalCode () at
#18 0x00007fffa9c7c351 in () at
#19 0x00007fffa9d0adf3 in () at
#20 0x00007fffa9b24ffd in () at
#21 0x00007fffa9b2906b in _PyEval_EvalFrameDefault () at
#22 0x00007fffa9b300db in () at
#23 0x00007fffa9d5380a in () at
#24 0x00007fffa9b24ffd in () at
#25 0x00007fffa9b2d467 in _PyEval_EvalFrameDefault () at
#26 0x00007fffa9c7779b in _PyEval_EvalCodeWithName () at
#27 0x00007fffa9d52bb0 in _PyFunction_Vectorcall () at
#28 0x00007fffa9d5380a in () at
#29 0x00007fffa9b24ffd in () at
#30 0x00007fffa9b2d467 in _PyEval_EvalFrameDefault () at
#31 0x00007fffa9c7779b in _PyEval_EvalCodeWithName () at
#32 0x00007fffa9d52bb0 in _PyFunction_Vectorcall () at
#33 0x00007fffa9d5380a in () at
#34 0x00007fffa9b24ffd in () at
#35 0x00007fffa9b2d467 in _PyEval_EvalFrameDefault () at
#36 0x00007fffa9b300db in () at
#37 0x00007fffa9d5380a in () at
#38 0x00007fffa9b24ffd in () at
#39 0x00007fffa9b2d467 in _PyEval_EvalFrameDefault () at
#40 0x00007fffa9b300db in () at
#41 0x00007fffa9d5380a in () at
#42 0x00007fffa9b24ffd in () at
#43 0x00007fffa9b2d467 in _PyEval_EvalFrameDefault () at
#44 0x00007fffa9b300db in () at
#45 0x00007fffa9d53783 in () at
#46 0x00007fffa9d532ac in PyVectorcall_Call () at
#47 0x00007fffe0b26d6c in () at
/usr/lib/python3/dist-packages/sip.cpython-38-x86_64-linux-gnu.so
#48 0x00007fffe0b26e4f in () at
#49 0x00007fffe03000ff in () at
/usr/lib/python3/dist-packages/PyQt5/Qsci.cpython-38-x86_64-linux-gnu.so
#50 0x00007fffe038b446 in () at
#51 0x00007ffff3e93d82 in QWidget::event(QEvent*) () at
/usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#52 0x00007ffff3f3f9ce in QFrame::event(QEvent*) () at
#53 0x00007ffff3f425a1 in QAbstractScrollArea::event(QEvent*) () at
#54 0x00007ffff0f7b213 in QsciScintilla::event(QEvent*) () at
/usr/lib/libqscintilla2_qt5.so.15
#55 0x00007fffe038bc0a in () at
#56 0x00007ffff3e51c32 in QApplicationPrivate::notify_helper(QObject*,
QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#57 0x00007ffff3e5b8c6 in QApplication::notify(QObject*, QEvent*) () at
#58 0x00007ffff4dc6877 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7fffffffcb80, receiver=0x5555613f76a0, event=0x7fffffffbfe0) at
../src/core/qgsapplication.cpp:426
#59 0x00007ffff3454a52 in QCoreApplication::notifyInternal2(QObject*,
QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#60 0x00007ffff3eb1eee in () at
#61 0x00007ffff3e51c32 in QApplicationPrivate::notify_helper(QObject*,
#62 0x00007ffff3e5b190 in QApplication::notify(QObject*, QEvent*) () at
#63 0x00007ffff4dc6877 in QgsApplication::notify(QObject*, QEvent*)
(this=0x7fffffffcb80, receiver=0x55555df85ab0, event=0x7fffffffbfe0) at
#64 0x00007ffff3454a52 in QCoreApplication::notifyInternal2(QObject*,
#65 0x00007ffff3831f63 in
QGuiApplicationPrivate::processKeyEvent(QWindowSystemInterfacePrivate::KeyEvent*)
() at /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#66 0x00007ffff3837251 in
QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*)
#67 0x00007ffff3811ecb in
QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#68 0x00007fffcf630cda in () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#69 0x00007fffebad560d in g_main_context_dispatch () at
/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#70 0x00007fffebad5890 in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#71 0x00007fffebad591f in g_main_context_iteration () at
#72 0x00007ffff34aa7c1 in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#73 0x00007ffff34536db in
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at
#74 0x00007ffff345b182 in QCoreApplication::exec() () at
#75 0x000055555556b99d in main(int, char**) (argc=1,
argv=0x7fffffffde78) at ../src/app/main.cpp:1608
Is this helpfull for any core dev?
Should I create an issue?
Regards,
Richard
