[QGIS-Developer] Processing algorithms in Qgis serveur
David Marteau dmarteau at 3liz.com
Thu Apr 23 05:45:05 PDT 2020
Hi Patrick,
If you want to run processing algorithm in qgis server you will need to
write a dedicated server plugin for that, if may fullfill your
needs if you are not too much demanding. If you intend to run Qgis
processing as a service then I strongly suggest to look at the WPS
protocol in a dedicated
server.
Le 23/04/2020 à 14:02, Jorge Gustavo Rocha a écrit :
> Hi Patrick,
> David Marteau did a presentation in FOSS4G related with QGIS Server and
> server side processing. Please check
> https://www.youtube.com/watch?v=YL1tdcJwimA
> Regards,
> Jorge Gustavo
> On 23/04/20 06:26, PALMIER Patrick (Responsable de groupe) -
> CEREMA/DTerNP/DATHa/MT wrote:
>> Hello,
>> Is there any documentation, tutorial or examples to show how to run
>> processing algorithms in Qqis server?
>> Thanks
>> Patrick Palmier
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
David Marteau
Responsable Infrastructure
www.3liz.com <http://www.3liz.com>
*Tel*. 06 63 02 89 83
*Bureau*
31, rue de l'Argenterie
34000 Montpellier
*Siège social*
73, allée Kleber
Boulevard de Strasbourg
34000 Montpellier
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200423/e9aab5da/attachment-0001.html>
More information about the QGIS-Developer mailing list
