[QGIS-Developer] Mesh layer
Vincent Cloarec
vcloarec at gmail.com
Sun Apr 26 07:34:49 PDT 2020
With QGIS master you can use updateTriangularMesh.
<https://qgis.org/pyqgis/master/core/QgsMeshLayer.html#qgis.core.QgsMeshLayer.updateTriangularMesh>
Before, there is a workaround that consists to just call createMapRenderer
<https://qgis.org/pyqgis/3.12/core/QgsMeshLayer.html#qgis.core.QgsMeshLayer.createMapRenderer>
without using the renderer.
Vincent
Le sam. 25 avr. 2020 à 11:32, Jorge Almerio <jorgealmerio at yahoo.com.br> a
écrit :
> Hi everyone,
> Sometimes I got "NaN" return when trying to get scalar value to a point
> from a Mesh layer. I guess the reason is that it was not rendered
> previously as said in the documentation.
> https://qgis.org/api/classQgsMeshLayer.html#a07cb62f04b64979500d3873afb580216
> QgsMeshDatasetValue:
> "Note:
> It uses previously cached and indexed triangular mesh and so if the
> layer has not been rendered previously (e.g. when used in a script) it
> returns NaN value"
> When I turn ON and OFF the loaded mesh layer in the active project it
> Works!
> I would like to know if there is a proper way to render the mesh layer,
> before get values.
> Below is my code:
> proj = QgsProject.instance()
> layerPto = iface.activeLayer() # a Point layer
> layer = proj.mapLayersByName("mesh01")[0] # a Mesh layer
> dataset = QgsMeshDatasetIndex(0,0)
> for feat in layerPto.getSelectedFeatures():
> ptoGeo = feat.geometry()
> pt = ptoGeo.asPoint()
> value = layer.datasetValue(dataset, pt).scalar()
> print('elevation={}'.format(value))
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200426/4ae92545/attachment.html>
