[QGIS-Developer] Understanding inter-plugin dependencies and plugin loading - what can a plugin expect from a dependency?
Alessandro Pasotti
apasotti at gmail.com
Tue Apr 28 23:53:34 PDT 2020
On Tue, Apr 28, 2020 at 7:38 PM Sebastian M. Ernst
<ernst at pleiszenburg.de> wrote:
> Hi all,
> sorry for my lengthy email last week - but this issue is still spinning
> in my head and blocking progress in my test-bed plugin installer
> re-implementation.
> PR#9619 actually has two interesting comments ...
> https://github.com/qgis/QGIS/pull/9619#issuecomment-476499538
> https://github.com/qgis/QGIS/pull/9619#issuecomment-476550817
> ... in terms of use-cases for inter-plugin dependencies, their current
> limitations and their (potential) correct use. The second comment is
> interesting in terms of how one plugin should correctly expose a
> "stable" API to other plugins: By injecting code into `qgis.plugins` *at
> runtime* and exposing something like for instance
> `qgis.plugins.QuickWkt`. The idea is interesting but it essentially
> suffers from what I described: The absolutely non-deterministic loading
> sequence. So it is not an actual, reliable solution at the moment -
> unless the plugin requiring this API does some serious checking prior to
> accessing its desired API and calls into the mostly undocumented API of
> `qgis.utils` as a fallback solution.
> How should a plugin author handle this at the moment (with QGIS 3.8 to
> 3.12)?
> Best regards,
> Sebastian
Hi Sebastian,
it's not entirely clear to me what problem you are trying to solve,
but as far as loading of python modules is concerned, it is probably
useful to distinguish two situations:
1. installation of a plugin that depends on another one
2. plugin loading when QGIS application start
For (1) there is not much you can do except try/except and/or warn the
user that a QGIS application restart might be required for the plugin
to work after the dependencies have been installed.
For (2) you can have a plugin listen to initializationCompleted, at
that point in time all your plugins will be loaded, and the plugin can
make its own "post-initialization".
Hope this helps.
Kind regards.
> Am 23.04.20 um 20:46 schrieb Sebastian M. Ernst:
> > Hi all,
> > working my way through the current plugin (dependency) installer
> > mechanism, I have a few questions.
> > Bottom line: What kind of assumptions can a plugin safely make about its
> > dependencies and their initialization (from QGIS' perspective)?
> > Imagine two plugins: "PluginA" and "PluginB". PluginA depends on
> > PluginB, i.e. if a user was installing PluginA, current QGIS would ask
> > him to install PluginB as well.
> > Now the plugin system in QGIS does three things actually:
> > - Installing and uninstalling plugins
> > - Loading (i.e. importing, in Python terms) and unloading plugins
> > - Starting and stopping (`initGui` + friends and `unload`)
> > In comparison, typical package managers usually do not care about the
> > loading and starting part. This is because usually a package installer
> > does run outside of the scope of the stuff that is using the packages.
> > So if a user was installing PluginA in QGIS, the following sequence
> > would be triggered:
> > - Install PluginA
> > - Find dependencies of PluginA: PluginB
> > - Install PluginB
> > - Load PluginB
> > - Start PluginB
> > - Load PluginA
> > - Start PluginA
> > PluginB would be loaded (imported) and started before PluginA. Depending
> > on the use-case, this can make a lot of sense. Unfortunately, if a user
> > was restarting QGIS, the loading and starting sequence would depend on
> > (as it appears) the order of plugin folders on the filesystem which can
> > be more or less "random". So here, PluginA can not rely on PluginB to
> > have been loaded and/or started in advance at the moment.
> > This leads to many potential problems, some of which were discussed here
> > (Nyall's comment being the most interesting one for me):
> > https://github.com/qgis/QGIS-Enhancement-Proposals/issues/132#issuecomment-460136324
> > So the question now is: How is PluginA supposed to interact with PluginB?
> > Thanks to the way `sys.path` is configured in QGIS, PluginA could easily
> > run `import PluginB` and it would actually work. QGIS has a modified
> > `builtins.__import__` method which would even track this import. This
> > would sort of allow to treat PluginB as a "normal" Python package and be
> > equivalent to `qgis.utils.loadPlugin("PliginB")`, for better or for worse.
> > A possible alternative is that PluginA requires PluginB to initialize
> > itself through `classFactory` (or `serverClassFactory`). PluginA's best
> > (and probably safest) option then would be to run
> > `qgis.utils.startPlugin("PluginB")` (or `startProcessingPlugin` /
> > `startServerPlugin`). PluginA could now basically access the instance of
> > PluginB's class through `qgis.utils.plugins["PluginB"]` (or
> > `server_plugins`).
> > All of the above is fragile in many ways and - as far as I can tell -
> > more or less undocumented. How much of the described API in `qgis.utils`
> > is supposed to be available to "the public", i.e. to plugins?
> > As far as I can see, only one plugin (for QGIS 3.8 or later) in the
> > plugin repository actually uses inter-plugin dependencies (properly), so
> > there are not many examples of how things should look like. QEP 132 also
> > is not really detailed about the exact behavior and assumptions a
> > plugin's author can make. Fortunately, the current lack of "downstream"
> > users and the lack of "established" documentation opens the option to
> > "fix" the system without breaking too much stuff if desired.
> > Final questions:
> > - How is the *current* plugin-dependency system supposed to be used /
> > not supposed to be used from your perspective?
> > - How do you envision an actual plugin-dependency system to work (with
> > respect to interactions between plugins)?
> > - Does it make sense to care about plugin dependencies when QGIS is
> > loading and starting plugins (so dependencies are loaded & started first)?
> > Best regards,
> > Sebastian
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
