[QGIS-Developer] Broken PyQgsServerWMSGetPrint - about to disable
René-Luc D'Hont rldhont at gmail.com
Thu Apr 30 23:03:55 PDT 2020
Hi Nyall,
I have opened an issue about it and tried to fix it with no clue.
https://github.com/qgis/QGIS/issues/35973
https://github.com/qgis/QGIS/pull/35984
The segfault appears randomly since I tried to fix a regression and added
more PyQgsServerWMSGetPrint tests.
Before deactivate the PyQgsServerWMSGetPrint test, it will be great to
merge the pull request to provide better QGIS Server code.
Regards,
René-Luc
Le ven. 1 mai 2020 à 07:15, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
> On Fri, 1 May 2020 at 15:04, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
> > On Fri, May 1, 2020 at 3:35 AM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
> > > Hi list,
> > > Just a heads up that unless someone fixes the recently flaky
> > > PyQgsServerWMSGetPrint test I'll be adding this test to the travis
> > > blacklist shortly.
> > > This test is randomly crashing with no clues -- see e.g.
> https://cdash.orfeo-toolbox.org/testDetails.php?test=18996963&build=40255
> > > I've spent some time trying to diagnose the cause with no luck, and
> > > cannot afford to spend more time on this.
> > > You've 24 hours to respond/fix.. ;)
> > Hi Nyall,
> > I agree, but today is holiday in most countries and and I would
> > probably wait until monday.
> > That test is quite important, it saved our day a few times in the past.
> Ok, it gets a stay of execution till Monday :P
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200501/1d1fde57/attachment.html>
More information about the QGIS-Developer mailing list
