[QGIS-Developer] Interpretation of qgisMaximumVersion in metadata.txt
Sebastian M. Ernst ernst at pleiszenburg.de
Sat Aug 1 07:56:18 PDT 2020
Hi Borys, all,
> Actually it was never properly synchronized between the installer and
> the repo.
which adds another question ... how is the repo (i.e. QGIS-Django?)
handling it?
> For the installer, both lower and upper boudary are included, so it makes
> more sense to set it to 3.98 rather than 3.99.
Ok, thanks.
> By the way - putting 0 to the third
> position makes yet less sense ;) If you put just 3.98, it will be
> automatically extended to 3.98.99 [1].
It's my parser that fills in the zeros. I need to refine this logic.
> The key thing is even setting the maximum to 3.99 will work, because the
> current "pyQgisVersion" of QGIS 3.99 is recognized as 4.0! See [2].
This was raising my initial question in the first place.
Best regards,
Sebastian
More information about the QGIS-Developer mailing list
