[QGIS-Developer] Inconsistencies in QGIS ini path
DelazJ delazj at gmail.com
Mon Aug 17 08:54:40 PDT 2020
Le lun. 17 août 2020 à 16:56, Tim Sutton <tim at kartoza.com> a écrit :
> Hi Richard
> Thanks for your reply - see below for inline responses:
> On Mon, Aug 17, 2020 at 12:32 PM Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
>> On 8/17/20 9:23 AM, Tim Sutton wrote:
QStandardPaths.standardLocations(QStandardPaths.AppDataLocation)
>> in the pythonconsole shows:
>>  '/home/richard/.local/share/QGIS/QGIS3',
>>  '/usr/share/gnome/QGIS/QGIS3',
>>  '/home/richard/.local/share/flatpak/exports/share/QGIS/QGIS3',
>>  '/var/lib/flatpak/exports/share/QGIS/QGIS3',
>>  '/usr/local/share/QGIS/QGIS3',
>>  '/usr/share/QGIS/QGIS3'
>> Can you test this on a mac?
> Heheh once you leave mac, you can never go back :-) Hopefully someone
> looking in from macOSland on the list here if they can test.
> On a mac, I get (using 3.10 from the all-in-one installer)
['/Users/harrissou/Library/Application Support/QGIS/QGIS3',
'/Library/Application Support/QGIS/QGIS3',
'/Applications/QGIS3.10.app/Contents/Resources']
On Windows, using an osgeo4w advanced install, with master:
['C:/Users/harrissou/AppData/Roaming/QGIS/QGIS3',
'C:/ProgramData/QGIS/QGIS3',
'C:/OSGEO4W64/bin',
'C:/OSGEO4W64/bin/data',
'C:/OSGEO4W64/bin/data/QGIS/QGIS3']
HTH,
Harrissou
>> IF it is different, I think it is better to adhere to Qt-standards then
>> to build those path's ourselves?
> Well the issue I am trying to highlight is that the config folder as
> currently implemented is not portable. I thought it was part of the design
> intent of switching to ini based configs way back that there was a
> homogenous system for managing configurations. Currently having <PROFILE
> NAME>/qgis.org/QGIS3.ini on a mac and <PROFILE NAME>/QGIS/QGIS3.ini on
> linux (curious to know what Windows does) breaks the principle of least
> surprise and means that your settings folder isn't portable between
> machines when it easily could be,
> Regards
> Tim
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> Tim is a member of the QGIS Project Steering Committee
> Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200817/211f86d6/attachment-0001.html>
More information about the QGIS-Developer mailing list
