[QGIS-Developer] use qt 5.10 for CI tests
Matthias Kuhn
matthias at opengis.ch
Thu Aug 27 05:45:07 PDT 2020
Hi Peter,
I don't see a problem to conditionally disable shadows for Qt <= 5.10, we
also have other conditions depending on the Qt version in other parts of
the codebase.
Is there a hidden question how to go about testing this in CI? If yes, I'd
say the best approach would indeed be to enable tests for Qt 5.14.
Best regards
Matthias
On Thu, Aug 27, 2020 at 1:58 PM Peter Petrik <
peter.petrik at lutraconsulting.co.uk> wrote:
> Hi,
> CI on travis runs with qt 5.9 and for
> https://github.com/qgis/QGIS/pull/38448 we need to have qt 5.10+. In 5.9
> the 3d shadow rendering does not work correctly and since Windows, Mac and
> latest Linux distributions run on newer qt's I do not see a reason to spend
> considerable time to fix the 3d shadows for qt 5.9. I was thinking to
> disable this feature for builds with qt 5.9.I see the qt5.14 build in the
> repository, but that one is without tests.
> I am wondering how to best approach this?
> Thanks,
> Peter
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200827/4bedc0ea/attachment.html>
