[QGIS-Developer] QGIS at Apple Macbook Pro ARM M1? [Marketing Mail]
Elstermann, Mike
Mike.Elstermann at itc-halle.de
Thu Dec 3 09:45:42 PST 2020
You know this? „It's working here on the M1 MacBook Pro, QGIS 3.10.12. I just launched it and opened a map project; there might be glitches I haven't found."
See https://www.reddit.com/r/QGIS/comments/jxn1m7/anyone_tested_qgis_on_apple_silicon_rosetta_2/
mikeE., The #geoObserver.
http://www.geoobserver.de
> Am 25.11.2020 um 19:59 schrieb Elstermann, Mike <Mike.Elstermann at itc-halle.de>:
> Thanks Tim!
>> Do you already have an M1 device Mike? Have
>> you tested if PG and QGIS run under Rosetta2?
> No, I don't have an M1 Macbook yet, but I'm planning to get one soon and it would be good to know if QGIS/PG is running on it.
> Best regards, mikeE., the #geoObserver.
>> Am 25.11.2020 um 17:35 schrieb Tim Sutton <tim at kartoza.com>:
>> I think a starting point for that would be Peter Petrik
>> a) being funded to work on the port
>> b) having the hardware needed to do it (would be great if someone could sponsor a device for him)
>> Above assuming Peter is willing and available.
>> Do you already have an M1 device Mike? Have you tested if PG and QGIS run under Rosetta2?
>> Regards
>> Tim
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
