[QGIS-Developer] QGIS disables plugin on loading problem
Luca Manganelli
luca.manganelli at comune.trento.it
Sun Dec 6 05:29:52 PST 2020
Il giorno ven 4 dic 2020 alle ore 11:10 uclaros <uclaros at gmail.com> ha
scritto:
> I am doing the same thing with no issues by setting QGIS_PLUGINPATH to a
> shared network path. Users connect to the network via VPN and the plugin
is
> loaded automatically. If the VPN is down while QGIS is starting, the
plugin
> is not loaded, but connecting to the VPN and restarting QGIS brings
> everything to normal.
Strange. Not happening here: at following startups the plugin is never
re-enabled. I must re-enable it from the plugin list.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201206/335eb55c/attachment.html>
