[QGIS-Developer] Problem with plugin upload
Joona Laine
joona at gispo.fi
Mon Dec 7 03:27:23 PST 2020
Hi Jorge!
I removed those .gitignore files and tried again, but the problem persists.
-Joona
On Mon, 7 Dec 2020 at 13:10, Jorge Gustavo Rocha <jgr at di.uminho.pt> wrote:
> Hi Joona,
> I'm not sure if the problem was solved on the server side. I'm still
> getting this "For security reasons, zip file cannot contain '.git'
> directory" error with your plugin.
> Can you do one more test, please? Remove these .gitignore files and
> upload it again.
> ./resources/i18n/.gitignore
> ./resources/.gitignore
> ./resources/icons/.gitignore
> ./resources/ui/.gitignore
> ./logs/.gitignore
> Good luck!
> Jorge
> Às 11:04 de 07/12/20, Denis Rouzaud escreveu:
> > I just experienced the same issue a few minutes ago and it went back
> > to normal.
> > I thought it was thanks to a requirements.txt file removal, but I guess
> > it was a server issue.
> > On Mon, 7 Dec 2020, 11:38 Joona Laine, <joona at gispo.fi
> > <mailto:joona at gispo.fi>> wrote:
> > Hi Jorge!
> > Thanks for the fast reply! Here
> https://github.com/GispoCoding/FMI2QGIS/releases/download/0.1.1/FMI2QGIS.0.1.1.zip
> > is a link to the zip file I tried originally (version 0.1.1) and
> > here
> https://github.com/GispoCoding/FMI2QGIS/releases/download/0.1.0/FMI2QGIS.0.1.0.zip
> > is a link to the initial release zip file (version 0.1.0) that I
> > uploaded successfully on 1st December.
> > -Joona
> > <http://www.gispo.fi/>
> > On Mon, 7 Dec 2020 at 12:31, Jorge Gustavo Rocha <jgr at di.uminho.pt
> > <mailto:jgr at di.uminho.pt>> wrote:
> > Hi Joona,
> > Can you share a link to your zip file? It would help to see the
> > exact
> > contents you are trying to upload.
> > Regards,
> > Jorge Gustavo
> > Às 10:27 de 07/12/20, Joona Laine escreveu:
> > > Hello Folks!
> > > I noticed that there might be a problem with QGIS plugin
> > repository
> > > while uploading plugins. I tried to add a new version to a
> plugin
> > > (FMI2QGIS <https://plugins.qgis.org/plugins/FMI2QGIS/>) first
> via
> > > qgis-plugin-ci <https://github.com/opengisch/qgis-plugin-ci>
> > and then
> > > manually on web page, but both methods failed with error
> messages:
> > > <Fault 1: "File upload must be a valid QGIS Python plugin
> > compressed
> > > archive. For security reasons, zip file cannot contain '.git'
> > directory">
> > > and
> > > "There were errors reding plugin package (please check also
> your
> > > plugin's metadata). For security reasons, zip file cannot
> > contain '.git'
> > > directory".
> > > I double checked the metadata.txt file and made sure that
> > there were no
> > > .git -directory in the zip file but still the problem
> > persisted. I even
> > > tried to upload the previous version again with a different
> > version
> > > number to see if the problem might lie in the plugin upload
> > process
> > > instead and I couldn't upload that one either.
> > > Thanks!
> > > Best regards,
> > > Joona Laine, Gispo Ltd.
> > > _______________________________________________
> > > QGIS-Developer mailing list
> > > QGIS-Developer at lists.osgeo.org
> > <mailto:QGIS-Developer at lists.osgeo.org>
> > > List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > Unsubscribe:
> > J. Gustavo
> > Jorge Gustavo Rocha
> > Departamento de Informática
> > Universidade do Minho
> > 4710-057 Braga
> > Gabinete 3.29 (Piso 3)
> > Tel: +351 253604480
> > Fax: +351 253604471
> > Móvel: +351 910333888
> > skype: nabocudnosor
> > List info:
> > Unsubscribe:
> > QGIS-Developer at lists.osgeo.org <mailto:
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201207/2f0856de/attachment.html>
