[QGIS-Developer] Question on QGIS Authentication API
C Hamilton
adenaculture at gmail.com
Mon Feb 3 06:36:05 PST 2020
John,
Thanks for that hint. Here is what I finally used.
auth_mgr = QgsApplication.authManager()
conf_map = auth_mgr.availableAuthMethodConfigs()
for key in conf_map.keys():
name = conf_map[key].name()
print( key )
print( name )
So that gives me both the authentication id and its name. Thanks so much.
Calvin
On Mon, Feb 3, 2020 at 6:24 AM John Gitau <gkahiu at gmail.com> wrote:
> Hi Calvin,
> You can retrieve the name from the base config object as follows:
> for id, conf in conf_map.iteritems():
> conf_name = conf.name()
> print conf_name
> I hope this helps.
> Cheers,
> John
> On Fri, Jan 31, 2020 at 11:11 PM C Hamilton <adenaculture at gmail.com>
> wrote:
>> I can get a list of all of the authentication IDs in QGIS by these two
>> lines of code.
>> authMgr = QgsApplication.authManager()
>> authIdList = authMgr.configIds()
>> Starting from one of the authentication ids in the list I cannot seem to
>> find out how to retrieve its associated name. It is probably simple, but I
>> cannot find the right method to call. Does anyone know how to do it?
>> Thanks,
>> Calvin
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200203/9adb48d7/attachment.html>
