[QGIS-Developer] Insert data in a table with a table with a GENERATED column
Régis Haubourg regis.haubourg at gmail.com
Tue Feb 11 08:15:12 PST 2020
Oh, I see my master is old. I thought I recompiled it last week. I'll check
again. Let's compile.
Regards
Régis
Le mar. 11 févr. 2020 à 15:12, Alessandro Pasotti <apasotti at gmail.com> a
écrit :
> Wierd, I thought I fixed that: there is a test too,
> https://github.com/qgis/QGIS/pull/34017/files#diff-99b101819133a316786604243f3abf6eR1432
> feel free to reopen and provide additional test details or test cases.
> On Tue, Feb 11, 2020 at 3:05 PM Régis Haubourg <regis.haubourg at gmail.com>
> wrote:
>> For the record here are my SQL commands:
>> drop table if exists data.pipe;
>> CREATE TABLE data.pipe
>>     id integer NOT NULL ,
>>     label_1_text character varying(120) COLLATE pg_catalog."default",
>>     _length2d numeric(8,2) GENERATED ALWAYS AS (st_length2D(geometry))
>> STORED,
>>     _length3d numeric(8,2) GENERATED ALWAYS AS (ST_3DLength(geometry))
>> STORED,
>>     geometry geometry(LineStringZ,3946) NOT NULL,
>>     CONSTRAINT pipe_pkey PRIMARY KEY (id)
>> INSERT INTO
>> "data"."pipe"("geometry","id","label_1_text","_length2d","_length3d")
>> VALUES (st_geomfromtext('LINESTRINGZ(1 1 1, 2 2 2)',3946),2
>> ,'test',DEFAULT, DEFAULT);
>> Le mar. 11 févr. 2020 à 15:03, Régis Haubourg <regis.haubourg at gmail.com>
>> a écrit :
>>> Hi Paolo,
>>> nice feature, thanks for the heads up !
>>> I confirm the behavior here.
>>> The documentation advises to use the `DEFAULT` keyword into the INSERT
>>> command.
>>> Here is what I get with a QGIS-like insert :
>>>  INSERT INTO
>>> VALUES (st_geomfromtext('LINESTRINGZ(1 1 1, 2 2 2)',3946),1 ,'test',0,  0);
>>> ERREUR:  42601: ne peut pas insérer dans la colonne « _length2d »
>>> DÉTAIL : Column "_length2d" is a generated column.
>>> EMPLACEMENT : rewriteTargetListIU, rewriteHandler.c : 827
>>> With the keyword 'DEFAULT', it works
>>> INSERT INTO
>>> And with no data supplied for the generated columns, it also works
>>> We indeed have to upgrade the postgresql provider to check this
>>> particular column type to handle INSERT and UPDATE accordingly.
>>> Regards
>>> Régis
>>> Le mar. 11 févr. 2020 à 13:59, Paolo Cavallini <cavallini at faunalia.it>
>>> a écrit :
>>>> Hi all,
>>>> PostgreSQL 12 has the option of a GENERATED ALWAYS AS ... STORED column.
>>>> QGIS is able to load the table, but apparently it is not possible to
>>>> insert new records. Does anyone confirm that this is not a local
>>>> problem?
>>>> All the best.
>>>> Paolo Cavallini - www.faunalia.eu
>>>> QGIS.ORG Chair:
>>>> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200211/ca7150dc/attachment-0001.html>
More information about the QGIS-Developer mailing list
