[QGIS-Developer] Insert data in a table with a table with a GENERATED column
Alessandro Pasotti
apasotti at gmail.com
Wed Feb 12 00:24:08 PST 2020
On Wed, Feb 12, 2020 at 9:05 AM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> HHhi all,
> thanks Alessandro for fixing it. Any hope to backport it to 3.4? This
Nope, 3.4 is EOL
there is a bp here for 3.10 though:
https://github.com/qgis/QGIS/pull/34291
raises again the issue of long term releases, and their interaction with
> upgrades of related sw.
> Cheers.
> Il 11/02/20 17:15, Régis Haubourg ha scritto:
> > Oh, I see my master is old. I thought I recompiled it last week. I'll
> > check again. Let's compile.
> > Regards
> > Régis
> > Le mar. 11 févr. 2020 à 15:12, Alessandro Pasotti <apasotti at gmail.com
> > <mailto:apasotti at gmail.com>> a écrit :
> > Wierd, I thought I fixed that: there is a test too,
> https://github.com/qgis/QGIS/pull/34017/files#diff-99b101819133a316786604243f3abf6eR1432
> > feel free to reopen and provide additional test details or test
> cases.
> > On Tue, Feb 11, 2020 at 3:05 PM Régis Haubourg
> > <regis.haubourg at gmail.com <mailto:regis.haubourg at gmail.com>> wrote:
> > For the record here are my SQL commands:
> > drop table if exists data.pipe;
> > CREATE TABLE data.pipe
> > id integer NOT NULL ,
> > label_1_text character varying(120) COLLATE
> > pg_catalog."default",
> > _length2d numeric(8,2) GENERATED ALWAYS AS
> > (st_length2D(geometry)) STORED,
> > _length3d numeric(8,2) GENERATED ALWAYS AS
> > (ST_3DLength(geometry)) STORED,
> > geometry geometry(LineStringZ,3946) NOT NULL,
> > CONSTRAINT pipe_pkey PRIMARY KEY (id)
> > INSERT INTO
> "data"."pipe"("geometry","id","label_1_text","_length2d","_length3d")
> > VALUES (st_geomfromtext('LINESTRINGZ(1 1 1, 2 2 2)',3946),2
> > ,'test',DEFAULT, DEFAULT);
> > Le mar. 11 févr. 2020 à 15:03, Régis Haubourg
> > <regis.haubourg at gmail.com <mailto:regis.haubourg at gmail.com>> a
> > écrit :
> > Hi Paolo,
> > nice feature, thanks for the heads up !
> > I confirm the behavior here.
> > The documentation advises to use the `DEFAULT` keyword into
> > the INSERT command.
> > Here is what I get with a QGIS-like insert :
> > INSERT INTO
> > VALUES (st_geomfromtext('LINESTRINGZ(1 1 1, 2 2 2)',3946),1
> > ,'test',0, 0);
> > ERREUR: 42601: ne peut pas insérer dans la colonne «
> > _length2d »
> > DÉTAIL : Column "_length2d" is a generated column.
> > EMPLACEMENT : rewriteTargetListIU, rewriteHandler.c : 827
> > With the keyword 'DEFAULT', it works
> > INSERT INTO
> > And with no data supplied for the generated columns, it also
> > works
> > We indeed have to upgrade the postgresql provider to check
> > this particular column type to handle INSERT and UPDATE
> > accordingly.
> > Regards
> > Régis
> > Le mar. 11 févr. 2020 à 13:59, Paolo Cavallini
> > <cavallini at faunalia.it <mailto:cavallini at faunalia.it>> a
> écrit :
> > Hi all,
> > PostgreSQL 12 has the option of a GENERATED ALWAYS AS
> > ... STORED column.
> > QGIS is able to load the table, but apparently it is not
> > possible to
> > insert new records. Does anyone confirm that this is not
> > a local problem?
> > All the best.
> > Paolo Cavallini - www.faunalia.eu <
> http://www.faunalia.eu>
> > QGIS.ORG <http://QGIS.ORG> Chair:
> > http://planet.qgis.org/planet/user/28/tag/qgis%20board/
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > <mailto:QGIS-Developer at lists.osgeo.org>
> > List info:
> > https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe:
> > List info:
> > Unsubscribe:
> > Alessandro Pasotti
> > w3: www.itopen.it <http://www.itopen.it>
> QGIS.ORG Chair:
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200212/b1cd2832/attachment-0001.html>
