[QGIS-Developer] WMS loaded in qgis desktop, not in server
Paolo Cavallini
cavallini at faunalia.it
Thu Feb 13 07:22:26 PST 2020
Hi Jeff,
I regularly use WMS services, and this is the first time I hit this
different behaviour between server and desktop, so I think this is
related to that specific server.
Cheers.
Il 13/02/20 16:19, Jeff McKenna ha scritto:
> On 2020-02-13 11:00 a.m., Paolo Cavallini wrote:
>> Indeed, adding
>> ?SERVICE=WMS&REQUEST=GetCapabilities
>> returns valid results.
>> curl from the same server downloads a valid image.
>> Unclear therefore why the layers are shown in desktop and not in the
>> server. Could it be that they do not allow wms cascading?
>> I worked around this by taking data directly from wms, without passing
>> from qgis server, but it would be nice to understand this behaviour.
>> Thanks Richard for the plugin, very useful.
>> Cheers.
> Paolo does the same issue occur when you leverage my server instead,
> inside your application? If so I can check my Apache logs when you hit
> it, to see what request your application is sending to MapServer.
> -jeff
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
