[QGIS-Developer] startup.py not working outside %APPDATA%\QGIS\QGIS3
Thomas Baumann rdbath.regiodata at gmail.com
Mon Feb 17 07:10:53 PST 2020
Hi QGIS-devs,
It looks like QGIS3 (tested with 3.10.2) does not make use of a startup.py
if it is saved outside
%APPDATA%\QGIS\QGIS3 (OS: Windows 10).
I opened QGIS with a custom "--profiles-path"  which works fine as QGIS
creates this profiles folder. But if you put a startup.py into this folder
(for example %APPDATA%\QGIS\qgis3_tests) it is not executed.
Only the startup.py saved in %APPDATA%\QGIS\QGIS3 is executed.
I guess this is a bug, isn't it?
Otherwise it would be not possible to have different startup.py files for
different profile folders (testing/production).
regards,
Thomas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200217/e2f2dd32/attachment.html>
More information about the QGIS-Developer mailing list
