[QGIS-Developer] Documentation bot
Alexandre Neto
senhor.neto at gmail.com
Mon Jan 6 09:47:14 PST 2020
Hi Denis,
Thanks this sounds much better than the previous solution.
Was the older bot deactivated? The one that creates tickets by commit with
the need-docs tag?
This means devs should no longer add the need-docs tag in individual
commits?
Thanks,
Alexandre Neto
A segunda, 6/01/2020, 12:57, Denis Rouzaud <denis.rouzaud at gmail.com>
escreveu:
> Dear Devs,
> This is a report for the QGIS grant proposal to create a documentation bot.
> This bot is now alive and automatically create an issue in the
> documentation repo for merged PR.
> ** How to use it **
> 1) Create a PR on qgis/QGIS
> 2) tag it with "Needs Documentation"
> 3) optionally set the milestone to it
> 4) merge it
> => an issue is automatically created in the qgis/QGIS-Documentation
> repository
> => you get a message telling you should take care of it
> Example:
> dummy PR: https://github.com/qgis/QGIS/pull/33627
> created issue: https://github.com/qgis/QGIS-Documentation/issues/4744
> I have left some notes next to the action, explaining how it works
> https://github.com/qgis/QGIS/blob/master/.github/workflows/pr_to_doc_issue.md
> Thanks to the community and QGIS.org for sponsoring this feature.
> Best wishes,
> Denis
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200106/0f1e5f32/attachment.html>
