[QGIS-Developer] core API to fetch query output fields from SQL query?
Alessandro Pasotti
apasotti at gmail.com
Fri Jan 10 00:03:21 PST 2020
On Thu, Jan 9, 2020 at 11:26 PM Tim Sutton <tim at kartoza.com> wrote:
>> In particular, me an Nyall have been chatting about adding a method to
>> factory a QgsVectorLayer from a generic SQL query, the issues I see is that
>> we need a PK (at least for PG) and how to decide the geometry column if
>> there are more than one.
> I wonder if you could just transparently add row_number[1] to the query to
> give each row a unique id?
> Regards
> Tim
> [1] https://www.postgresqltutorial.com/postgresql-row_number/
Hi Tim,
the example query I pasted in my original email does exactly that: (SELECT
row_number()....
we just need a bit of login to determine when/if we have to make that trick.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200110/c7e13730/attachment.html>
