[QGIS-Developer] Build failed on Azure CI, how to get details
René-Luc Dhont
rldhont at gmail.com
Thu Jan 16 03:01:04 PST 2020
Hi Devs,
Is the Azure CI mandatory before merging ?
Regards,
René-Luc
Le 15/01/2020 à 15:29, René-Luc Dhont a écrit :
> Hi Dev,
> My PRs https://github.com/qgis/QGIS/pull/33813 and
> https://github.com/qgis/QGIS/pull/33725 failed to build on Azure CI.
> The build log is minimalistic :
> 2020-01-15T10:12:39.7333036Z Build project
> 2020-01-15T10:12:39.7350985Z Each symbol represents 1024 bytes of output.
> 2020-01-15T10:12:39.7351096Z '!' represents an error and '*' a warning.
> 2020-01-15T10:21:19.1415558Z .............................................*.... Size: 49K
> 2020-01-15T10:36:14.5224541Z ..................*............................... Size: 99K
> 2020-01-15T10:49:37.5635400Z .......*****...................................... Size: 149K
> 2020-01-15T10:58:23.4653034Z ....******........................................ Size: 199K
> 2020-01-15T11:07:34.3517006Z .....*.......................*......**.......*** Size of output: 248K
> 2020-01-15T11:07:34.4586592Z Error(s) when building project
> 2020-01-15T11:07:34.4586766Z 1 Compiler errors
> 2020-01-15T11:07:34.4587572Z 56 Compiler warnings
> 2020-01-15T11:07:34.7983476Z [0/1] cmd.exe /C "cd /D D:\a\1\s\ms-windows\osgeo4w\build-qgis-dev-x86 && "C:\Program Files\CMake\bin\ctest.exe" -D ExperimentalSubmit"
> 2020-01-15T11:07:34.8127277Z Site: azure-pipelines
> 2020-01-15T11:07:34.8127629Z Build name: PR 33813 / master (1138) (d88e9cbd97) (qgis-dev Experimental x86)
> 2020-01-15T11:07:34.8147167Z Submit files
> 2020-01-15T11:07:34.8147322Z Send to track: Experimental
> 2020-01-15T11:07:34.8147841Z SubmitURL:https://cdash.orfeo-toolbox.org/submit.php?project=QGIS
> 2020-01-15T11:07:36.9734255Z Uploaded: D:/a/1/s/ms-windows/osgeo4w/build-qgis-dev-x86/Testing/20200115-1012/Build.xml
> 2020-01-15T11:07:37.4788307Z Uploaded: D:/a/1/s/ms-windows/osgeo4w/build-qgis-dev-x86/Testing/20200115-1012/Done.xml
> 2020-01-15T11:07:37.4789266Z Submission successful
> 2020-01-15T11:07:37.4891009Z build failed
> 2020-01-15T11:07:37.4896897Z BUILD ERROR 0: Wed 01/15/2020 11:07:37.47
> 2020-01-15T11:07:37.9186422Z ##[error]Cmd.exe exited with code '1'.
> 2020-01-15T11:07:38.0958787Z ##[section]Finishing: Building QGIS
> How to get details when the build failed ?
> Thanks
> René-Luc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200116/814ce135/attachment-0001.html>
