[QGIS-Developer] Environmental policy
Andreas Neumann
a.neumann at carto.net
Thu Jan 16 11:05:39 PST 2020
Yes, I'd also like to focus on the original issue:
QGIS.ORG should only fund train tickets for short distance travels to
QGIS contributor meetings (and come up with a definition what "short
distance" means).
The other discussions about restricting usage of QGIS is a "can of
worms". The world is not black and white and some substantial amount of
FOSSGIS software originated from military backgrounds.
Andreas
Am 16.01.20 um 19:27 schrieb Even Rouault:
> Regarding
>> prohibit the use of QGIS to the fossil-fuels industry.
> and
>> ...may I suggest to add GLOBAL PEACE & WAR issues to this QGIS
>> discussion on environmental questions ?
> That's not a good idea IHMO. Don't mix licensing & ethics. Free software
> licenses explicitly don't discriminate against fields of endehavor (see clause
> 6 of https://opensource.org/osd-annotated ), and adding discrimination is
> currently generally considered as being a bad idea and likely not enforcable
> in most juridictions, although they are debates around attempts at having
> ethical open source licensing
> (https://medium.com/@gmcgath/the-futility-of-the-hippocratic-license-b6a9ad981dec).
> Things can get really complex. For example, regarding prohibiting the use to
> the fossil-fuels industry, what about car makers: should they be considered as
> being part of the fossil-fuel industry, and thus prohibited from using the
> software and thus using proprietary mapping solution instead, etc etc. (Open
> Source) licensing is (or is perceived to be) a sufficiently complex topic
> already to not complicate it further.
> Personal note: my contributions to FOSS4G related software all started because
> I was able to use them in the context of working in the defense industry in my
> past life: is it about peace or war ? both, depending from the point of view.
> I should also remind, that for good or worse, the EPSG database that is
> critical to proper CRS management in our software is mostly maintained by
> IOGP.
> The world is complex.
> Even
