[QGIS-Developer] Plugin can only be loaded in qgis ltr dev
Jürgen E. Fischer
jef at norbit.de
Wed Jul 1 04:46:42 PDT 2020
Hi Sandra
On Wed, 01. Jul 2020 at 10:44:08 +0000, Sandra Raabe wrote:
> I have a Qt/C++-plugin, formally developed in QGIS 2, now updated to QGIS 3.
> The plugin is compiled to a DLL file. When I start qgis_ltr_dev.exe my
> plugin is loaded and works well. Unfortunately, no other version can load the
> plugin. I need to get it to work in a "normal" - not developmental version of
> QGIS.
> Any hint where problems could be? My suggestion was that different GDAL
> version in QGIS-Dev and QGIS might cause a problem.
Only the API is stable - the ABI is not. You have to build a version for each
QGIS version (or even each build).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200701/826dc81d/attachment.sig>
