[QGIS-Developer] webp for qgis server ?
Lucie Nicolier lucie at opengis.ch
Tue Jul 7 02:37:04 PDT 2020
>> Hi everyone,
>> I upgraded the blog-post with all command lines I used and how I get
>> the base TIF and the other formats from it.
>> Hope to see the parameters I used will explain the results we got.
>> I'm open to received recommendations to get better result.
>> Stay here for more information.
>> Regards,
>> Lucie
>> Lucie Nicolier
>> lucie at opengis.ch <mailto:lucie at opengis.ch>
>> +41 (0)79 276 67 76 <tel:+41792766776>
>> OPENGIS.ch Logo <http://www.opengis.ch>
>> Le 09.06.2020 à 14:01, Matthias Kuhn a écrit :
>>> Thanks for the excellent questions Even
>>> Lucie has done the analysis and has all the parameters. She is not
>>> in the office these days. Once she is back I hope she can share the
>>> parameters and potentially also add a couple of additional rows to
>>> the table with improved parameters.
>>> Sorry that I can't help more right now.
>>> Matthias
>>> On 6/9/20 1:56 PM, Even Rouault wrote:
>>>> Matthias,
>>>> thanks for the analysis. There are however a few unexpected results.
>>>> 1) I'd expect gpkg pyramid_JPEG and COG_JPEG to have very similar
>>>> sizes, even COG_JPEG being potentially slightly smaller.
>>>> And I'd also expect COG_JPEG to be slighly faster (but with less
>>>> confidence that my statement about size)
>>>> Has by chance the source raster an alpha band ? In which case
>>>> gpkg_pyramid_JPEG would have dropped it, whereas COG_JPEG will
>>>> encode it as DEFLATE compressed mask, but still the difference is
>>>> surprising
>>>> Another explanation might be the block size. GPKG defaults to
>>>> 256x256 tiles, whereas COG_JPEG to 512x512. Perhaps that affect
>>>> compression efficiency. And performance? (depends if your bench
>>>> maintains the GDAL raster opened between requests or not)
>>>> If you didn't specify quality settings, both COG_JPEG and GPKG JPEG
>>>> should use the same quality of 75%
>>>> 2) For the same compression type, block sizes and number of
>>>> overviews, MBTiles (the report doesn't specify the compression
>>>> scheme for it) and GeoPacakge should also have similar sizes and
>>>> performance. They are really close brothers, with just a few
>>>> systems tables different.
>>>> Even
>>>> > Hi all,
>>>> > At OPENGIS.ch we have recently looked into different raster
>>>> formats. The
>>>> > results can be read here:
>>>> https://www.opengis.ch/2020/06/09/offline-wms-benchmarking-raster-formats-fo
>>>> > r-qfield/
>>>> > Not that surprising, but one of the interesting findings was that
>>>> webp
>>>> > is very efficient. Low filesize, reasonable rendering performance,
>>>> > support for transparency. In short, it has all the potential for
>>>> being
>>>> > used as default transport format for WM(T)S.
>>>> > Looking at our server implementation, this format is not
>>>> supported. Did
>>>> > someone ever think about or even look into that?
>>>> > Regards
>>>> Spatialys - Geospatial professional services
>>>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200707/2e906b77/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200707/2e906b77/attachment.png>
More information about the QGIS-Developer mailing list
