[QGIS-Developer] QGIS symbology: jumping point and line pattern fills
Andreas Neumann a.neumann at carto.net
Thu Jul 9 02:36:10 PDT 2020
Hi Alexandre,
Thank you for this idea. I tried it. It sounded promising, but
unfortunately, it did not help.
Andreas
On 2020-07-09 11:27, Alexandre Neto wrote:
> Hi Andreas,
> Try disabling Clip Features to canvas extent on the advanced combobox (next to symbol levels)
> I think it fix what you are seeing.
> Alexandre Neto
> A quinta, 9/07/2020, 10:17, Andreas Neumann <a.neumann at carto.net> escreveu:
>> Hi,
>> Working recently extensively with point and line pattern fills, I noticed that with each pan, the point and line pattern fills in QGIS kind of "jump" around relatively to their geometry, as if the offset of the pattern was kind of "random".
>> You can see it in this video: https://www.youtube.com/watch?v=V4ytwM59_jY
>> Is there any setting so I can avoid this behavior? Or could a QGIS dev with experience in symbology help fix this issue? I would assume if someone creates tiles from this, they would also run into issues at tile borders, because of this.
>> Thanks if you have any ideas.
>> Andreas _______________________________________________
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200709/64171867/attachment-0001.html>
More information about the QGIS-Developer mailing list
