[QGIS-Developer] How to get animation_datetime()
Andreas Neumann a.neumann at carto.net
Mon Jul 13 14:44:00 PDT 2020
I think I found it out.
I have to use
second(@frame_duration) * @frame_number
to get the nr of seconds from the start of the animation.
animation_datetime() seems to be something from the old time manager plugin.
Andreas
Am 13.07.20 um 23:25 schrieb Bernd Vogelgesang:
> Still not clear. Do you mean the timer running in the lower right?
> If so, see https://www.youtube.com/watch?v=vgDg5cRwPRw starting at 54:40
> for the formula
> On 13.07.20 23:14, Andreas Neumann wrote:
>> By "current time of an animation" I mean the current time represented
>> in the time slider control as a function or variable.
>> Thanks,
>> Andreas
>> Am 13.07.20 um 23:08 schrieb Andreas Neumann:
>>> Hi,
>>> In an animation (QGIS 3.14) - how do I get the current time of an
>>> animation?
>>> In https://www.youtube.com/watch?v=8R0TQlhdc1U&feature=youtu.be at
>>> minute 6:26, it shows a formula involving the "animation_datetime()"
>>> function.
>>> But my expression editor complains, that this function is not
>>> available.
>>> Thanks for your hints,
>>> Andreas
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
