[QGIS-Developer] How to get animation_datetime()
    Andreas Neumann
    a.neumann at carto.net
    Tue Jul 14 02:08:32 PDT 2020
Hi Nyall,
Thanks for clarifying - I confirm that @map_start_time and @map_end_time
where the values I was looking for!
I think we need a blog post or general introduction (preferably in the
QGIS manual) to decribe all the concepts of the temporal framework.
Something for 3.16 documentation ...
Thanks again,
Andreas
Am 14.07.20 um 10:59 schrieb Nyall Dawson:
> On Tue, 14 Jul 2020 at 18:44, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi Nyall,
>> hm - but @animation_start_time and @animation_end_time seems not to be moving along with the time slider. That remains "static" during the animation.
> ARgh - sorry, it's @map_start_time and @map_end_time. The @animation
> ones refer to the overall animation start and end times.
> Nyall
>> Based on your feedback I was expecting @animation_start_time and @animation_end_time to move along with the time slider - this doesn't seem the case.
>> Anyway - with second(@frame_duration) * @frame_number
>> and this is also a single point in time, relative to the beginning of the animation, not a "range" slice.
>> I get what I want (the current time representation value of the time slider). I just thought there might be something "easier".
>> I might not get the full concept of the new temporal framework - I have also to admit, that I didn't really use the TimeManager plugin a lot - maybe with this background, things would have been clearer to me.
>> Thanks,
>> Andreas
>> Am 14.07.20 um 00:39 schrieb Nyall Dawson:
>> On Tue, 14 Jul 2020 at 07:44, Andreas Neumann <a.neumann at carto.net> wrote:
>> animation_datetime() seems to be something from the old time manager plugin.
>> Correct -- the new temporal framework works on the concept of a map
>> having a time range, not a single time instant.
>> The equivalent variables are:
>> - @animation_start_time
>> - @animation_end_time
>> Nyall
>> Andreas
>> Am 13.07.20 um 23:25 schrieb Bernd Vogelgesang:
>> Still not clear. Do you mean the timer running in the lower right?
>> If so, see https://www.youtube.com/watch?v=vgDg5cRwPRw starting at 54:40
>> for the formula
>> On 13.07.20 23:14, Andreas Neumann wrote:
>> By "current time of an animation" I mean the current time represented
>> in the time slider control as a function or variable.
>> Thanks,
>> Andreas
>> Am 13.07.20 um 23:08 schrieb Andreas Neumann:
>> Hi,
>> In an animation (QGIS 3.14) - how do I get the current time of an
>> animation?
>> In https://www.youtube.com/watch?v=8R0TQlhdc1U&feature=youtu.be at
>> minute 6:26, it shows a formula involving the "animation_datetime()"
>> function.
>> But my expression editor complains, that this function is not
>> available.
>> Thanks for your hints,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
