[QGIS-Developer] Compiling QGIS with 3D failing
matteo
matteo.ghetta at gmail.com
Mon Jul 20 00:17:55 PDT 2020
Hi all,
I got an error when compiling QGIS with 3D support on Debian SID:
......a bunch of similar lines......
/usr/bin/ld: CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart5.cpp.o:
in function `sipQgs3DAlgorithms::sipProtectVirt_loadAlgorithms(bool)':
sip_3dpart5.cpp:(.text+0x8a98): multiple definition of
`sipQgs3DAlgorithms::sipProtectVirt_loadAlgorithms(bool)';
CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart4.cpp.o:sip_3dpart4.cpp:(.text+0x8ea0):
first defined here
/usr/bin/ld:
CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart5.cpp.o:(.data.rel.local+0x420):
multiple definition of `sipTypeDef__3d_Qgs3DAlgorithms';
CMakeFiles/python_module_qgis__3d.dir/3d/sip_3dpart4.cpp.o:(.data.rel.local+0x580):
first defined here
collect2: error: ld returned 1 exit status
make[2]: ***
[python/CMakeFiles/python_module_qgis__3d.dir/build.make:817:
output/python/qgis/_3d.so] Error 1
make[2]: Leaving directory '/home/matteo/dev/qgis-master'
make[1]: *** [CMakeFiles/Makefile2:5772:
python/CMakeFiles/python_module_qgis__3d.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs..
if the 3D support is deactivated then all is working fine.
not sure which commit introduced this problem.
Cheers and thanks
Matteo
