[QGIS-Developer] using conda for development
    Matthias Kuhn
    matthias at opengis.ch
    Fri Jul 31 00:27:23 PDT 2020
One thing to keep in mind is that even the main qgis
installers/distributions do not have fixed dependency versions. Using
downloaded macOS QGIS will have different dependencies than Windows and
so will all the linux/*nix flavors.
On 7/31/20 7:14 AM, Ari Meyer wrote:
> @Nyall, that proposal appears to be specific to plugins -- not sure if
> that's the best place to discuss this issue.
> @Greg: I found that many of the exact dependencies were not even
> available through the main channels.  So if the QGIS devs
> compile/build against such versions, I'm not sure there's an easy way
> to even specify such a conda recipe, unless all those dependencies are
> also made available somehow.  I didn't expect that those versions
> would not even be there with the others for the various libraries.
> Could this imply that the library developers don't want those versions
> to be used?  Not sure.
> As a user and developer, I just want to be sure that if I pull down
> conda-forge qgis version X that I will get the same effective
> distribution as contained in downloadable installer version X.  Right
> now, we are getting a very different set of dependencies.
> Thanks,
> Ari
> On Thu, Jul 30, 2020 at 6:44 PM Greg Troxel <gdt at lexort.com
> <mailto:gdt at lexort.com>> wrote:
>     Nyall Dawson <nyall.dawson at gmail.com
>     <mailto:nyall.dawson at gmail.com>> writes:
>     > There's a related proposal at
>     > https://github.com/qgis/QGIS-Enhancement-Proposals/issues/179 --
>     > probably best to keep the discussion on that page.
>     Not really about the details of using conda but about the concept:
>       conda's documentation says it runs on "Windows, macOS and Linux" but
>       qgis also runs on at least NetBSD and almost certainly other BSDs.
>       it seems that to build something, including qgis the requirement is
>       that the things it depends on are present in some way that is
>     found by
>       the build.  People can choose to do that however they want, and it
>       seems funny to me to impose a requirement.   If this is really
>     "let's
>       publish a conda config file so that people who want to do that
>     can do
>       less work", that's of course fine, but if it's more "if you
>     don't have
>       conda then you can't build qgis", that's something else.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200731/2da6ad07/attachment.html>
