[QGIS-Developer] Issues with CRS in QGIS master on Ubuntu 20.04
Pedro Venâncio pedrongvenancio at gmail.com
Mon Jun 1 16:19:24 PDT 2020
Hi Even,
Your answer made the bells ring! It was OTB 7.1.0 that was configured in
environment variables, with older PROJ.
Everything fine now!
Thank you very much Even! And sorry for the noise!
Best regards,
Pedro
Even Rouault <even.rouault at spatialys.com> escreveu no dia segunda,
1/06/2020 à(s) 23:40:
> > No transform is available between EPSG:3763 - ETRS89 / Portugal TM06 and
> > Unknown CRS: GEOGCRS["unknown",DATUM["unknown",ELLIPSOID["GRS 1….
> > proj_create_operations: cannot build geodeticCRS 4326: SQLite error on
> > SELECT name, ellipsoid_auth_name, ellipsoid_code,
> prime_meridian_auth_name,
> > prime_meridian_code, area_of_use_auth_name, area_of_use_code,
> > publication_date, deprecated FROM geodetic_datum WHERE auth_name = ? AND
> > code = ?: no such column: publication_date
> You have definitely a mix of PROJ versions. Your PROJ library tries to
> access the proj.db of an older version.
> > Then I get several others, involving EPSG:4326, EPSG:3857 and Unknown
> CRS.
> > Another issue is that, apparently, QGIS does not recognize the prj file
> > from shapefiles, even if it was created by himself. For instance, this
> > sample shapefile
> https://drive.google.com/uc?export=download&id=1e7WxgPoSeTx7RiZHIaxdX0kvL8Uu
> > Ok9Z
> Works for me. Related to your above issue
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200602/2147fa5f/attachment.html>
More information about the QGIS-Developer mailing list
