[QGIS-Developer] webp for qgis server ?
Matthias Kuhn matthias at opengis.ch
Tue Jun 9 05:01:41 PDT 2020
Thanks for the excellent questions Even
Lucie has done the analysis and has all the parameters. She is not in
the office these days. Once she is back I hope she can share the
parameters and potentially also add a couple of additional rows to the
table with improved parameters.
Sorry that I can't help more right now.
Matthias
On 6/9/20 1:56 PM, Even Rouault wrote:
> Matthias,
> thanks for the analysis. There are however a few unexpected results.
> 1) I'd expect gpkg pyramid_JPEG and COG_JPEG to have very similar
> sizes, even COG_JPEG being potentially slightly smaller.
> And I'd also expect COG_JPEG to be slighly faster (but with less
> confidence that my statement about size)
> Has by chance the source raster an alpha band ? In which case
> gpkg_pyramid_JPEG would have dropped it, whereas COG_JPEG will encode
> it as DEFLATE compressed mask, but still the difference is surprising
> Another explanation might be the block size. GPKG defaults to 256x256
> tiles, whereas COG_JPEG to 512x512. Perhaps that affect compression
> efficiency. And performance? (depends if your bench maintains the GDAL
> raster opened between requests or not)
> If you didn't specify quality settings, both COG_JPEG and GPKG JPEG
> should use the same quality of 75%
> 2) For the same compression type, block sizes and number of overviews,
> MBTiles (the report doesn't specify the compression scheme for it) and
> GeoPacakge should also have similar sizes and performance. They are
> really close brothers, with just a few systems tables different.
> Even
> > Hi all,
> > At OPENGIS.ch we have recently looked into different raster formats. The
> > results can be read here:
> https://www.opengis.ch/2020/06/09/offline-wms-benchmarking-raster-formats-fo
> > r-qfield/
> > Not that surprising, but one of the interesting findings was that webp
> > is very efficient. Low filesize, reasonable rendering performance,
> > support for transparency. In short, it has all the potential for being
> > used as default transport format for WM(T)S.
> > Looking at our server implementation, this format is not supported. Did
> > someone ever think about or even look into that?
> > Regards
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200609/c2771e73/attachment.html>
More information about the QGIS-Developer mailing list
