[QGIS-Developer] backporting nightmare
Nyall Dawson nyall.dawson at gmail.com
Tue Mar 3 23:04:58 PST 2020
On Wed, 4 Mar 2020 at 17:01, Matthias Kuhn <matthias at opengis.ch> wrote:
> On 3/4/20 7:48 AM, Denis Rouzaud wrote:
> Le mer. 4 mars 2020 à 02:56, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>> On Wed, 4 Mar 2020 at 10:48, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> > If it's just a buggy backport bot, then that's bad timing on my part, after all my dwindling spare time it took me to get caught up on my Mac build, I get this.
>> It is. The bot got seriously crippled by an upstream change, and now
>> it's a coin toss on the results you'll get.
> I plan to give another approach a try during the HF.
> The idea would be to use a CLI tool (https://github.com/sqren/backport or https://github.com/chainer/backport) which would be run a cron workflow.
> Using a cron will avoid the issues of PR from forks (the workflow user has rights to create branches).
> Hopefully these tools work better than the current bot.
> The only drawback I see up to now is that you'll have to wait for the cron to start (30min?).
> It looks like the bot fails on cherry-picking merge commits and would (likely) do fine if a `-m` option was provided - at least that's what's missing from the commands in the comment.
> Maybe it's as easy as adding this?
it still depends on "merges" instead of rebases... and I'm not a fan
of merge commits in general. They really make the git history messy
and difficult to read...
Nyall
> Matthias
>> > Don't Panic
> Let's try ;)
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
