[QGIS-Developer] GeoPDF not available with GDAL 3.0.4
Andreas Neumann
a.neumann at carto.net
Mon Mar 9 01:39:28 PDT 2020
Strange. I also compiled against GDAL/OGR 3.04 - and it is not greyed
out.
However, I have an older QGIS version and an older qt version (5.9.5)
than you. Not sure if that matters.
Andreas
On 2020-03-09 09:32, matteo wrote:
> Hi Andreas,
>> In the QGIS About dialogue - does it also say that QGIS was built with
>> GDAL 3.0.4?
>> Just to make sure that there aren't multiple GDAL versions on your
>> system and QGIS could be linked against an older version?
> yep:
> QGIS version
> 3.13.0-Master
> QGIS code revision
> 0f229208a7
> Compiled against Qt
> 5.12.5
> Running against Qt
> 5.12.5
> Compiled against GDAL/OGR
> 3.0.4
> Running against GDAL/OGR
> 3.0.4
> Compiled against GEOS
> 3.8.0-CAPI-1.13.1
> Running against GEOS
> 3.8.0-CAPI-1.13.1
> Compiled against SQLite
> 3.31.1
> Running against SQLite
> 3.31.1
> PostgreSQL Client Version
> 12.2 (Debian 12.2-1)
> SpatiaLite Version
> 4.3.0a
> QWT Version
> 6.1.4
> QScintilla2 Version
> 2.11.2
> Compiled against PROJ
> 6.3.1
> Running against PROJ
> Rel. 6.3.1, February 10th, 2020
> OS Version
> Debian GNU/Linux bullseye/sid
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200309/2d9ca782/attachment.html>
