[QGIS-Developer] GeoPDF not available with GDAL 3.0.4
    Andreas Neumann
    a.neumann at carto.net
    Mon Mar  9 03:00:57 PDT 2020
Hi Matteo,
if the output of
gdalinfo --formats | grep -i pdf
doesn't read like
 PDF -raster,vector- (rw+vs): Geospatial PDF
then yes, you'd need to compile GDAL/OGR yourself.
Andreas
On 2020-03-09 10:57, matteo wrote:
>> I compiled it with poppler
>> ./configure --with-python=python3 --with-proj=/usr/local --with-pg=yes
>> --with-poppler
> so gdal should be manually compiled to enable geopdf?
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200309/5829c295/attachment.html>
