[QGIS-Developer] Creating a WMS layer via PyQGIS triggers segfault
Trey Stafford trey.stafford at nsidc.org
Wed Mar 11 14:20:32 PDT 2020
Note that we also tried the same code with qgis v3.12.0, with the same
result.
On 3/11/20 3:05 PM, Trey Stafford wrote:
> Hello,
> We have encountered a problem in attempting to create WMS layers using
> PyQGIS (QGIS version 3.10.1 - installed from conda-forge).
> Attempting to create a QgsRasterLayer with the `wms` provider results
> in a segmentation fault.
> The following is a reproducible example. Running this code will cause
> the segmentation fault. Tested on Ubuntu 18.04.1, python 3.8.2.
>     import qgis.core as qgc
>     # Supply path to qgis install location
>     qgc.QgsApplication.setPrefixPath("/path/to/qgis/installation", True)
>     url = "http://www.glims.org/mapservice?VERSION=1.3.0&STYLES="
>     print(qgc.QgsRasterLayer(url, 'GLIMS_GLACIERS', 'WMS'))
> The only output from running the above code is the following (return
> code 139):
>     Segmentation fault (core dumped)
> Any advice or suggestions would be appreciated. If no one has any
> feedback, we will open a bug report.
> Thanks,
> Trey Stafford & Matt Fisher
> National Snow and Ice Data Center (NSIDC)
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200311/1de7a16e/attachment.html>
More information about the QGIS-Developer mailing list
