[QGIS-Developer] compare failing/succeeding CI builds (how to?)
Nyall Dawson nyall.dawson at gmail.com
Wed Mar 18 15:27:04 PDT 2020
On Wed, 18 Mar 2020 at 05:32, Sandro Santilli <strk at kbt.io> wrote:
> > This one not expected. What gdal/proj version do you use?
> I'm reporting what Travis says, so whatever GDAL/PROJ version is
> running on Travis. This is the run of this PR:
> https://github.com/qgis/QGIS/pull/31980
Hm, in that case something you've done has broken (or at least
changed) the test...
Nyall
More information about the QGIS-Developer mailing list
