[QGIS-Developer] QGIS 3.12 -- please stick to stable proj 6 releases!
Pedro Venâncio
pedrongvenancio at gmail.com
Sat Mar 21 17:56:26 PDT 2020
Hi Nyall and Jürgen,
I'm seeing that qgis-ltr-dev (3.10.3-14) installed from OSGeo4W is now
compiled against GDAL 3.1.0dev and PROJ 7.1.0:
QGIS version
3.10.3-A Coruña
QGIS code revision
d398423393 <https://github.com/qgis/QGIS/commit/d398423393>
Compiled against Qt
5.11.2
Running against Qt
5.11.2
Compiled against GDAL/OGR
3.1.0dev
Running against GDAL/OGR
3.1.0dev
Compiled against GEOS
3.8.1-CAPI-1.13.3
Running against GEOS
3.8.1-CAPI-1.13.3
Compiled against SQLite
3.29.0
Running against SQLite
3.29.0
PostgreSQL Client Version
11.5
SpatiaLite Version
4.3.0
QWT Version
6.1.3
QScintilla2 Version
2.10.8
Compiled against PROJ
7.1.0
Running against PROJ
Rel. 7.1.0, August 1st, 2020
OS Version
Windows 10 (10.0)
This copy of QGIS writes debugging output.
qgis-ltr (3.10.3-1) is compiled against GDAL 3.0.4 and GDAL 6.3.1:
QGIS version
3.10.3-A Coruña
QGIS code revision
0e1f846438 <https://github.com/qgis/QGIS/commit/0e1f846438>
Compiled against Qt
5.11.2
Running against Qt
5.11.2
3.0.4
3.0.4
3.8.0-CAPI-1.13.1
3.8.1-CAPI-1.13.3
3.29.0
3.29.0
11.5
SpatiaLite Version
4.3.0
QWT Version
6.1.3
QScintilla2 Version
2.10.8
6.3.1
Rel. 6.3.1, February 10th, 2020
OS Version
Windows 10 (10.0)
Is this the pretended behaviour? It's because there is another change in
GDAL/PROJ in an ongoing LTR release, and I'm afraid that it can lead to
similar problems occurred in QGIS 3.4 with GDAL/PROJ.
Best regards,
Pedro Venâncio
Nyall Dawson <nyall.dawson at gmail.com> escreveu no dia terça, 18/02/2020
à(s) 23:03:
> Hi list (especially Jürgen),
> Can we please ensure that the upcoming QGIS 3.12 and 3.10.3 releases
> use the stable PROJ 6.3.1 release, and not the 7.0 release (that's
> assuming that the final proj 7.0 release is out before the QGIS
> releases).
> https://github.com/OSGeo/PROJ/issues/1942 is a serious regression for
> QGIS users, and we **need** to get some QGIS releases out with stable
> projection handling. (I suggest we stick with the 6.x versions until
> PROJ 7.1 or later, and then re-investigating whether the timing is
> appropriate to upgrade QGIS windows builds to proj v7).
> (I realise the qgis-dev releases use proj-dev, which I think is fine
> (and actually useful to get wider testing/feedback on the newer proj
> releases). It's only the stable QGIS releases I'm concerned about)
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200322/3bd8fd94/attachment.html>
