[QGIS-Developer] Testing QGIS Plugin
Matthias Kuhn
matthias at opengis.ch
Mon Mar 23 04:26:20 PDT 2020
Hi Etienne,
I partially but respectfully disagree. I agree that other tools are
better for this use case. But a mock (dummy) interface is still a valid
tool to check which API's are called how many times and in which way on
a headless testing server / CI. Also on QGIS 3.
Best regards
Matthias
On 3/23/20 12:11 PM, Etienne Trimaille wrote:
> The dummy interface was mainly with QGIS 2. You don't need it anymore.
> You can read :
> https://github.com/qgis/QGIS/tree/master/.docker
> I will try to make a PR on qgis about Docker this week about some
> notes I have.
> Le lun. 23 mars 2020 à 11:48, Jo <winfixit at gmail.com
> <mailto:winfixit at gmail.com>> a écrit :
> What I found on the internet involves creating a dummy interface,
> which is great if you want to do Continuous Integration and such,
> but this wasn't the way I wanted to test. I wanted to be able to
> see what was happening right there in the live GUI.
> It took a while before I discovered that there is a mini editor in
> the Python console. Now I'm launching my test code from there and
> this works great. QTest allows me to press buttons or enter values
> and unit testing allows me to verify it's all as expected.
> I can show you in about half an hour, if you're available, or later.
> Jo
> On Mon, Mar 23, 2020 at 11:15 AM shiva reddy <kotishiva at gmail.com
> <mailto:kotishiva at gmail.com>> wrote:
> Sure.
> Looking forward to it.
> Thanks & Regards
> Shiva Reddy K.
> Scientist/Engineer 'SE’
> Indian Institute of Remote Sensing,
> Indian Space Research Organisation
> Department of Space
> 4-Kalidas Road
> Dehradun
> mobile: 0135-2524126
> On Mon, 23 Mar 2020 at 15:38, Jo <winfixit at gmail.com
> <mailto:winfixit at gmail.com>> wrote:
> Hi,
> I've been advancing a bit on the testing topic. I'll
> gladly do a Googe Hangout with you. We can probably learn
> from each other.
> Jo
> On Mon, Mar 23, 2020 at 11:01 AM shiva reddy
> <kotishiva at gmail.com <mailto:kotishiva at gmail.com>> wrote:
> Hi,
> Due to ongoing COVID 19 situation , I get unique
> opportunity for refine my skills by incorporating best
> practices into my open source projects.
> In this line, I would like to develop test cases for
> my QGIS plugin.
> Any idea , reference or any mentor who can guide me
> through this?
> My plugin name is QRealTime.
> Thanks & Regards
> Shiva Reddy K.
> Department of Space
> 4-Kalidas Road
> Dehradun
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200323/bb4f0067/attachment-0001.html>
