[QGIS-Developer] Frage
Raymond Nijssen
r.nijssen at terglobo.nl
Mon Mar 23 05:21:00 PDT 2020
Hi Sebastian,
Here's a little python script that works on a vector layer containing 2
lines. Just as an example.
Hope it helps,
Raymond
# calculates the maximum distance between 2 lines
# in the active vector layer
line_layer = iface.activeLayer()
nf = line_layer.featureCount()
if not nf == 2:
print('layer must have 2 features')
else:
feat1 = line_layer.getFeature(1)
geom1 = feat1.geometry()
feat2 = line_layer.getFeature(2)
geom2 = feat2.geometry()
max_dist = 0
vert1 = geom1.vertices()
for p1 in vert1:
vert2 = geom2.vertices()
for p2 in vert2:
dist = p1.distance(p2)
if dist > max_dist:
max_dist = dist
max_p1 = p1
max_p2 = p2
if max_dist > 0:
print('max distance: {})'.format(max_dist))
print('LINESTRING({} {}, {} {})'.format(
max_p1.x(), max_p1.y(), max_p2.x(), max_p2.y() ))
On 22-03-2020 16:13, Jorge Gustavo Rocha wrote:
> Hi Sebastian,
> Are you looking for a function like ST_MaxDistance [1] available in
> PostGIS?
> I'm not aware of such function in QGIS, but it can be implemented in PyQGIS.
> Best regards,
> Jorge Gustavo
> [1] http://postgis.net/docs/ST_MaxDistance.html
> On 22/03/20 13:50, Sebastian Hess wrote:
>> Sehr geehrte Damen und Herren,
>> ich benutze die QGis-version 3.12.0 und hätte ein Frage:
>> Gibt es in QGIs eine Funktion, mit der man den Punkt mit dem maximalen
>> Abstand zwischen zwei Lininen herausfnden kann, und dann den
>> dazugehörigen Wert des Abstandes in Metern erhält.
>> Mit freundlichen Grüßen
>> Sebastian Heß
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
