[QGIS-Developer] QGIS build error in Ubuntu 18.04
Samweli smwltwesa6 at gmail.com
Mon Mar 30 08:13:56 PDT 2020
Recently when I build QGIS from ubuntu 18.04 after an update on gdal
libraries from ubuntu repositories, I get this error
[ 67%] Running crssync
free(): invalid pointer
Aborted
src/crssync/CMakeFiles/synccrsdb.dir/build.make:57: recipe for target
'src/crssync/CMakeFiles/synccrsdb' failed
make[2]: *** [src/crssync/CMakeFiles/synccrsdb] Error 134
CMakeFiles/Makefile2:4322: recipe for target
'src/crssync/CMakeFiles/synccrsdb.dir/all' failed
make[1]: *** [src/crssync/CMakeFiles/synccrsdb.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 67%] Building CXX object
tests/src/core/CMakeFiles/qgis_sqliteutilstest.dir/qgis_sqliteutilstest_autogen/mocs_compilation.cpp.o
[ 67%] Built target qgis_25drenderertest
[ 67%] Linking CXX executable ../../../output/bin/qgis_sqliteutilstest
[ 67%] Built target qgis_hstoreutilstest
[ 67%] Built target qgis_sqliteutilstest
Makefile:162: recipe for target 'all' failed
Running *dpkg -l | grep gdal *gives this output
ii  libproj-dev:amd64
7.0.0-1~bionic0                          amd64        Cartographic
projection library (development files)
ii  libproj19:amd64
projection library
ii  libwebrtc-audio-processing1:amd64                           0.3-1
amd64        AudioProcessing module from the WebRTC project.
ri  proj-data
7.0.0-1~bionic0                          all          Cartographic
projection filter and library (datum package)
ii  python3-incremental                                         16.10.1-3
all          Library for versioning Python projects.
ii  python3-jupyter-core                                        4.4.0-2
all          Core common functionality of Jupyter projects for Python 3
ii  python3-pyproj
2.5.0+ds-1~bionic0                       amd64        Python 3 interface to
PROJ library
ii  xfwm4
4.12.5-1ubuntu0.18.04.1                  amd64        window manager of the
Xfce project
and running *dpkg -l | grep gdal*
ii  gdal-bin
3.0.4+dfsg-1~bionic0                     amd64        Geospatial Data
Abstraction Library - Utility programs
ii  gdal-data
3.0.4+dfsg-1~bionic0                     all          Geospatial Data
Abstraction Library - Data files
ii  libgdal-dev
Abstraction Library - Development files
ii  libgdal26
Abstraction Library
ii  python3-gdal
3.0.4+dfsg-1~bionic0                     amd64        Python 3 bindings to
the Geospatial Data Abstraction Library
Any help will truly be appreciated. Thanks.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
