[QGIS-Developer] QGIS Server `allowMethod` in Python server plugin not executed
Dražen Odobašić drazen.odobasic at quaternion.co
Mon May 4 00:48:16 PDT 2020
Hi Alessandro,
if `allowMethod` is simply going to be removed, QGIS-documentation has to be updated. I've created the issue https://github.com/qgis/QGIS/issues/36163
If it's going to be removed I could probably create an PR for QGIS and QGIS-documetation :)
Dražen
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Saturday, May 2, 2020 10:17 PM, Alessandro Pasotti <apasotti at gmail.com> wrote:
> On Sat, May 2, 2020 at 3:27 PM Dražen Odobašić
> drazen.odobasic at quaternion.co wrote:
> > Hi,
> > I've been toying around with QGIS Server Python plugins and it seems like `allowMethod` in QgsService does not get executed. A simple `git grep allowMethod` on the master branch shows few definitions but not sure if it's actually called from anywhere (maybe some external lib does actually invoke it, don't know)
> > Is this method actually used and how does it get called? Maybe it does work in C++, but not in Python?
> Hi Dražen,
> I think that you actually spotted an API leftover. I don't think that
> that method is needed, the best place for all checks is probably
> executeRequest where the service/API can decide if a request is valid
> according to its internal logic.
> But of course if we want to keep it we should at least check for the
> HTTP method before we accept the request.
> Would you please file a ticket?.
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
More information about the QGIS-Developer mailing list
